Originally Posted by Skippy722
Originally Posted by Ws6
Originally Posted by kstanf150
I was hoping for more but the flat tq curve looks really good for N/A engine
This is a stock LS3 dyno...
That Ford has another 1.1L on it. Keep in mind the dyno shows WHP numbers and not the flywheel Ford is showing. Add 20% for drivetrain loss and the LS3 put out 457hp/450tq.
Ford needs to do more development.
Your comparing engine dyno numbers to a chassis dyno. A Dyno Dynamics will read significantly different than a DynoJet which will read significantly different than a Mustang dyno. And then you're comparing an LS3 to a truck engine... would you like some apples to compare to your oranges?
Whatever. Ford can go back to their drawing board. An extra 1.1L sure didn't do much for 'em.
That is an L86 engine. A 6.2L that GM stuffed in trucks ever since 2014.
http://www.duramaxhub.com/gas/gm-6.2-ecotec3-l86.html
That is Fords answer. 1.1L more and over half a decade later. Weak AF.
Enjoy them oranges.
Enjoy them oranges.
