This is the UOA results on my 2007 Ford F-350 w/6.0L Power Stroke. I went 9,443 miles w/no make up oil & was still at the full mark right before I drained it. I idled this truck around 4 hours & hauled my truck camper around for 5,146.9 miles at a hair over 13,000 lbs GVWR. Several days were over 100 F. I had to remove the left valve cover & 2 fuel injectors to push out some broken glow plug connectors. I was thinking their would be a spike in silicon due to that work but to my surprise there was not.
If you'd like to see the oil filter on this run click here ---> Ford F-350 Filter
If you'd like to compare this particle count to the particle count on my Onan generator with no oil filter click here ---> Onan Gen UOA
It was quite revealing how much a filter can remove contaminates than an engine w/o an oil filter.
