I may want to do a dump and fill on my Titan at some point but the manual does not give you a fluid capacity . It's an 8 speed I think . Gas burner . Any ideas ?
A 2018 Titan will have the 7spd. A drain/fill may be around 4qts. You have to fill through a threaded port on the pan. Have you looked at the procedure?
I did it in my own way on our old Armada. There's a yamaha adapter that also works like the Nissan tool. I connected mine to an empty fertilizer spray container so that I could pump it back in the trans. I measured what came out(cold trans) and put back in the same.
