I recently did my first oil change on my 08 accord v6 @ 56.3k. The old dino oil was pretty black with a couple of viscous globs, so I'm going to run a few cycles of low mileage OCI's with PP and PU until things clean up.
Which brings me to filters. My current oil is PP with a Honda A02 filter, which after doing some reading on its quality, will be my last. Honda suggests changing the filter every other oil change. I plan on swapping this batch of PP out after 3k and refilling with PU for a 5k interval. In my application, should I use the same filter or swap in a new one?
I've also read that the Honda A01 filters are a much better part than the A02, so I bought four of them. Seeing that it's made by Filtech, is it pretty much the same as a Bosch Premium? If the Bosch is superior, would it be wise to use it with the PU refill in order to better capture any remaining crud in my engine and use the A01s once things are cleaned up?
Thanks, in advance, for your thoughts.
