Originally Posted By: gathermewool
Is there any correlation between particulate ejection and wear, prior to cycling through and being RE-captured by the media? Again, what is the practical detriment to running an automotive filter to 10k. I can’t think of any.
IMO, the more times a particle goes round-and-round through the engine the more potential wear there can be. So if a filter is continually shedding debris and 'recapturing' after a few passes then the total number of particles flowing through the engine will be higher over the OCI than if the filter retained more of the debris.
Also, I would not run a low efficiency filter very long because from what I've correlated is that a lower efficiency filter will shed more particles than a higher efficiency filter as the delta-p increases. This stems from the way the ISO efficiency is calculated which is the average efficiency of the filter from new to nearly fully loaded. If the ISO efficiency is high at a low micron rating (ie. say 99% @ 20 microns) then that means the media wasn't shedding much debris due to delta-p increasing over the test duration. In the graph posted in my previous post, the ISO efficiency would be calculate at 75% @ 20 microns, which is the average between beginning and end of test.
As far as the accelerated ISO test ... yeah, it doesn't represent 'real world loading', but it does show an apples to apples comparison between filters tested the same way. If you or anyone can show me that a filter that tests very badly in the ISO test is magically the best filter in 'real world use' then I'd like to see the data/proof. Accelerated efficiency testing in the lab correlated to the best filter also being the best filter in real world use in the "Bus Study". Based on what I've seen, the ISO efficiency test gives a good comparison on how filters will perform in real world use with respect to each other.
