I've always had success with Mahle and Felpro. Even in Asian applications. The replacements always appear to be of a better quality and different material than OE. At least, a fair sight better than the old, crumbly black, hard as nails stuff from the factory.
I just did an oil filter plate bypass gasket in a Felpro that was a GM factory fitted oil cooler line set. (On the side of the pan right above the filter boss) The OE gasket that pressed between the boss and cooler block was oval, steel, with nitrile (I think) grommets in just the passage holes.
The Felpro was the same shape, steel underneath... but entirely encapsulated in a thin rubber. Both the bolt holes for the line block and the oil cooler line holes had an in-cast rubber grommet. Essentially a triple seal and gasket kit. Snugged it up to spec...(In inch-pounds... it doesn't take much!) Dry as a bone.
If it lasts on that for another 17~18 years like the OE part? Gravy!
If not? Really. It's not expensive or difficult to swap again.
Edit: Still waiting for a good 4 hour span of clear weather. I've got a Felpro valve cover gasket kit w/grommets and a fresh oil filter and oil change just *dying* to go into service. I'll post unedited engine porn while she's opened up. I cannot speak to is life before I have kept her, but I've done right by the manual and OLM for the past 4 years. Full synthetics, OEM+ level of filters. Will the 12k miles of ownership been productive? Was it's first 168k miles been totally abhorrent? The mind boggles. Nails will be chewed. Dogs will lay in peace in the presence of cats. The mysteries of...
Not really. I do expect a decently clean valvetrain though. ^.^
If not, I expect my BITOG bros and sisters to just dog pile on my butt.
