http://www.autospeed.com/cms/A_2232/article.html
Just after I changed my filter tonight, I read this!!!!
On a stock engine in that application only. Most people looking for this increase have a modified engine and a car with a much more cramped intake system.quote:
Originally posted by c502cid:
When I was at the True Flow facility getting my intake system put on they pretty much verified this. True Flow uses the factory airbox, a foam (Uni) filter, and a modified free flow intake tube. They told me that the factory filters flow every bit, plus some, of the air needed to supply the engine. They said the horsepower increase comes from the air tubes, not the filter. While they feel their filter is superior to stock in filtering capabilities, they had nothing bad to say about flow of the factory paper element.
Btw, my application is a 2003 Chev 2500HD with the 8.1/Allison.
Thats what I was trying to point out. Its not a 2.5 dia circle. Its more like 1.8-2.0 internal diameter, and those ribs are effecting the maximum effective diameter as well, and inducing turbulence to the incoming air stream.quote:
I don't see how a 4x6 filter can flow more then a 2.5" dia circle.
Actually I can measure the inside of the ribbed tube, I'd say it's much bigger then 1.8-2.0" in diameter.quote:
I'll try and find a flow chart if I can on the effect of those ribs. Its pretty depressing what it does to the intake charge.
I see what your saying, but I still stand by my belief that an intake like this can benefit by a freer flowing filter. I will get some pics and measurements for physics sake.quote:
How deep is the box filter, how many pleats? Whats the inside diameter of the pipe? We can use physics and math here.
Remember I was estimating that because of the turbulence caused by the ribs, that the maximum theoretical internal diameter of the pipe would be less, due to the loss of efficency caused by the ribs.
Aka if the internal diameter was 2 inches (lets say for arguements sake). Its not going to flow the same as a straight 2.0 internal diameter smooth pipe. More like a 1.5-1.75 pipe.
