Originally Posted By: fdcg27
Originally Posted By: ArcticDriver
There is a starburst on the container. It will have a CJ-4 or CK-4 rating for diesel.
It will also have a /SM or /SN rating if it is compatible for gasoline engines. (Example: CK-4/SN)
The new CK-4/SN oils promise superior lubrication to the older CJ-4/SM rated oils.
It depends on your specific manufacturer recommendation but typically HDEO (heavy diesel engine oils) are fine for gasoline engines except they are of higher viscosity than gasoline motor oils nowadays which are trending towards 0W-20's for fuel economy.
umm, no, no starburst. The API starburst is reserved for energy conserving oils and none of the dual rated HDEOs are.
Maybe you meant the API donut?
Any dual rated HDEO will have the donut in which the diesel (compression ignition, hence the "C") spec comes first and the spark ignition ("S", get it?) spec comes second.
These are generally high HTHS oils and are well suited to engines calling for a thicker oil.
Old German cars come to mind.
They're intended to be used in fleets having both diesel trucks and heavy equipment as well as some gasser pickups and passenger cars. No need for the fleet operator to stock separate oil for the gassers.
These oils work well in this use and can work well in any spark ignition engine.
Got some T5 in one of my gassers ATM and I haven't owned a diesel in twenty years.
Thank God you are here to correct that horrible blunder.
You are right, it is not a starburst...it is a donut.
You quite likely saved this poster hours of effort searching through jugs and bottles of countless oils looking for a starburst rather than a donut...a circle with the letters CK-4/SN.
I am forever in your debt
I am not sure what all the talk is of old german cars, I will skip to the bottom, "this oil works in any spark ignition engine".
Yes, it will work...but many new cars are recommended to run on much thinner viscosity oils and HDEOs are not typically found in 0W-20.
Cheers
Cheers
