I'm not sure what more I can say. I've replaced two low mileage clutches due to slippage when I used non JASO oils. I've had other clutches I've saved when the non JASO oil started to slip and I replaced with JASO oils. I've had fellow riders who said they thought their clutches were slipping, found out they did not use JASO oils, replaced with JASO oils and the clutches quit slipping. I've had other riders that didn't realize their clutches were slipping using non JASO oils, switched to JASO oil, and voila they found more immediate response in their motorcycles as soon has they twist the throttle, instead of a rise in RPM then followed by acceleration.
AFAIK, all the wet clutch motorcycles manufactured since 1998 all list JASO MA or MB oil to be used. The cost is the same as other oils that are not JASO, so why not use it? There are JASO MA oils available for $1.98 if price is an issue. I've tried lots of JASO and non JASO oils in my motorcycles and my friends have too, and we know which work best for our bikes. That is the most important criteria.
