Originally Posted by Reddy45
Originally Posted by blupupher
ZZMan, same here, I have been using one since 2005, still on original machine. I have adjusted the pressure myself over the years (higher as I gained weight, .
I thought it takes a computer to change the pressure? I would love mine bumped up a little. I'm too cheap to want to go through another sleep study though.
What machine do you have? Some you can do yourself, others you need their software.
The Resmed S8 can be done pretty easily.
Just google "adjust pressure on xxxx" and you should get several results.
It is not something you want to just mess with though unless you know a little about what your doing.
As a nurse that works with ventilators and CPAP in emergent situations, I have a decent understanding of it, but it really is not super complicated.
What are your thoughts on the idea that CPAPs are overprescribed nowadays? In other words it seems like.. if you get a sleep study.. you WILL get a cpap prescription. It doesn't matter if you are perfectly healthy or if you could simply drop a few lbs.. the docs and clinics seem to have a perverse incentive to sell these devices.
Unfortunately you're correct.
