Originally Posted By: pavelow
If you can beat on your engine harder than this, you need to get a job as a GM engineer to up the ante. For example-one of GM's torture tests used on its ZL1 crate engines. "This engine has passed GM's 50-hour durability torture-test, where the engine is continuously run at full throttle, cycling back and forth between peak torque and peak power in 125-rpm, 10-25-millisecond increments." I'm sure their production torture tests are as brutal, if not more brutal. LOL.
However brutal these tests are; the effects of G loading, both laterally and under braking are not taken into account when you race an engine on a dyno(perhaps Porsche does!)
