- Joined
- Jun 8, 2022
- Messages
- 5,676
I had the same "problem" with my 2008 Xterra, used valvoline conventional for years. Just try some different brands until you find one you like.
The first I tried was Castrol semi syn but it made my valve covers leak more. Granted they need fixing, but its not a measurable amount with certain oils, but the castrol it poured out. Then I did the Havoline box - great product, worked fine, but then couldn't find any during the pandemic - valve covers stopped leaking again mostly. Did one change with clearance Supertech - the old stuff - worked fine, but can't find it. Then had a couple bottles of Quaker state - the old bottle - worked fine but again can't find it now - its the 'every engine" designation now- might be the same, who knows. Next 2 changes will be the Chevron I already have - ordered at Walmart.
I would do the Havoline box but I have this irrational fear is it will leak on my floor somehow?
None of the above has grenaded my engine.
