Originally Posted By: Nick1994
Yup, I added an auxiliary switch to the electric fan on my Jeep. If I turn the switch on, the CEL comes on for "open fan circuit" but when I turn the switch off, later that day the CEL goes away.
Doesn't bother me. When it's due for emissions I just won't turn the fan switch on for a couple days (it comes on automatically too).
But what's the point of manually controlling that fan if it normally comes on when intended? Just for your peace of mind in that AZ heat?
The fan comes on at too high of a temp IMO, I'd like to turn it on while out off-roading in the desert and sand and leave it on to prevent those high temperatures.
Turning the A/C on also turns the fan on, but it cycles. Sometimes I want the fan on in the desert with no a/c as well
If you are tapped into the fan relay and triggering it that way, you can add a diode between the pcm and where you are tapping off. Then it wont see you closing the relay.
Wow, thanks! I'll have to look into how to wire that in
Understandable; most vehicles with 190-195 thermostats have the fan set to come on 210-215. Can be really hot espically if you have a in-tank ATF cooler and are doing low speed high load, exactly like off road.
That code is a bit different than the Chevy I modded with a fan switch previously; on that one is was complaining about a short to ground, which was true since I was grounding the relay. Just a diode prevented it from seeing ground through my switch, but still allowed it to ground the relay when my switch was off.
The Jeep must be looking for voltage on the fan relay pin. The around 80 ohm relay would be essentially battery voltage at the PCM pin (might have like a 10k resistor pulling it down) until it turns its transistor on. When you ground it, it does not see any voltage, so it throws a code for open fan relay.
Good news is, I was right about the diode, we will need that. A 1 amp rated one such as a 1N400x type is suitable. But we will also need a resistor. 1k ohm should be low enough to provide voltage to it, and is high enough that a 1/4W one will work at normal vehicle voltages (up to 15V or so).
