CarbonSteel
- Joined
- Sep 26, 2010
- Messages
- 9,807
Stop trying it until it's confirmed that it's been adjusted ? I tried it, it didn't seem to stick, others said the same, so I stopped....It is more than a little annoying to have a feature that does not work.
Yes, the add-on I installed to close forums isn't able to remember your settings from session to session. We can either keep the add-on, remove it, or look for one that remembers your settings. Thoughts?Well tried it again yesterday, came on this evening and it still is reverting.
Any idea on an ETA on this? I don't have this issue on other XF sites, so it is not them.
Since the current one doesn't work, keep the add-ons simple and get rid of it. When I say it doesn't work, is there really any benefit to a user to collapse sub-forums (every time) just for their current browsing session ? I can live without the option so if you don't look for a replacement, I'm fine... If you find one that works, I'll probably use it.We can either keep the add-on, remove it, or look for one that remembers your settings. Thoughts?
No; not logging out. The setting just does not stick and it seems to last about 48 hours or so then all of the collapsed forums re-expand.For those of you who say the collapsed forum sections doesn't stay collapsed, are you logging out and logging back in? I've collapsed some sections and as long as I don't log-out they stay collapsed.
Same for me, but not even that long.No; not logging out. The setting just does not stick and it seems to last about 48 hours or so then all of the collapsed forums re-expand.
The functionality of this add-on is what it is. The author hasn't committed to making your settings sticky, so either we live with it the way it is, or we remove the add-on.Is this fixed?
Ah; ok. I was only asking because it appears to be working (but I could be dreaming)The functionality of this add-on is what it is. The author hasn't committed to making your settings sticky, so either we live with it the way it is, or we remove the add-on.
Can you clarify what you mean by working?Ah; ok. I was only asking because it appears to be working (but I could be dreaming)
I collapse them and they are remaining collapsed whereas the last time that I tried it, after a day or two they would expand again.Can you clarify what you mean by working?
