ls1mike
$50 Site Donor 2024
Originally Posted by maxdustington
Originally Posted by A_Harman
Agree. When the duty cycle changes to heavy duty, the engine design has to get conservative. I wouldn't want an aluminum block engine in a heavy duty pickup. I'd bet the 6.0 iron block can put out more power longer, under more severe conditions than the 6.2 L86.
I would, aluminum blocks are strong enough for race engines and high rpm use but not enough to lug a truck and trailer around below 5k rpm? If this were the case, aluminum blocks would be notorious for blowing up. I don't believe aluminum engine block durability is an issue in the 21st century, but I am not a metallurgist or automotive engineer. An aluminum block would be something cool to market, and a probable class exclusive.
The duty cycle is different in say 1/4 mile tracking my Trans Am with an aluminum block LS based motor, then say running up Vantage in 100 degree heat at 4200 to 5500 RPM for 10 to 15 minutes lugging 15,000 lbs total..
Like I said earlier it is the reason why big number, low ET LS cars are generally Iron block engines.. I have been messing with LS engines since they came out in 97. I had a 1998 Z28 new and have had at least two LS motors in my driveway a at time since. The Aluminum engines are really good but long term lots of hauling, towing high rpms for long periods of time or high hp low et cars it a no brainer to go to the iron block.
The 6.0 has a poo cam and poo heads. The change the Cam and heads and easily get 400hp out if with no change to the block or reliability.
