Changing oil filter only - 2024 Bronco 2.7L
How hard is an oil change on this thing?
If the filter has break in material, so does the oil. Get all of that out early, or just ride it out until the OLM tells you.
That’s the key - the debris flush and initial break in is done by 1k … it’s all slow motion after that … Is it needed? Who knows - but my last vehicle to use oil was a 79 PowerWagon at the valve stems …
I wouldn’t bother unless changing the oil. How do you like the Bronco? I’m looking at one for my wife, a Badlands, Sasquatch, 4DR with black painted hardtop.
I’m pushing for a Bronco Raptor but she’s not having it.
They have 4 2024's near me at 20000 off.
Hard to tell what’s needed or not. This is more of a precaution IMO. There could be lots of material floating in there or very little. Could be big chunks, or small.
Manufacturing processes vary to this day, it’s the nature of the beast. And there is no way of knowing which side of the quality bell curve the product we bought lands under.
The only sure to deal with this is to simply change the oil.
It's likely not necessary, but I'd change both the oil and the filter. My rec is to buy both at the dealer. Keep the receipt and start a maintenance log. I changed the oil and filter on my car at 1200 miles, and then again at 3000 miles.
I have the 2.7l EB in my 2025 Ranger. At 500 miles I dumped the factory fill, changed the filter and went with Amsoil. I purchased a Ronin oil drain plug and an UPR Products oil drain plug. I found the UPR plug to be a better design. I like that it has two gaskets going into the oil pan and that it has a ball drain valve, like a Fumoto drain plug. With the Ronin drain plug you need the screw-in piece to open up the valve. Both are very well built and have magnetic tips.
https://www.uprproducts.com/upr-for...-bronco/?searchid=267368&search_query=3025-03
https://www.amazon.com/dp/B07H56TP4F?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
The attached UOA confirmed my decision to change the oil.
As a prior 2.7 owner the filter never seemed loaded up and I mostl ended up following the OLM. It only started showing tiny metal filings when the chain got noisy on startup.
I did find changing the oil early when it was new as helpful - it consumed some and also “made” oil when it was early in life, and settled down by 20k miles nicely.
Thanks for all the suggestions. I’ve decided to wait until I get back.
I changed-out the oil & filter in both my Audis (purchased new) @ 1k miles. Since your oil filter is "on top", go buy an oil extractor, extract the oil, change the filter, and refill with new oil. You'll be done in a 1/2 hr. (tops). I perform oil and filter changes every 5k miles on my 2 Audis - both have cartridge filters in screw-on filter housings located in the "hot-V".
Since both engines have ~8-qt capacities, I bought a 10-qt capacity extractor:
https://www.ecstuning.com/b-bav-aut...p-stick-tube-bavarian-autosport/b8800001~bav/
Anyways, using an extractor is great because you don't have to mess with the drain plug, drain pans, putting the vehicle on ramps, or removing/installing the underbody panels (if applicable).
FWIW, the food pass app says ther is 55% oil life. Not sure if that is only time calculated or is it has considered anything else in the metrics for the 1.1k miles.
I would change the oil and filter now. The Motorcraft synthetic blend 5w30 factory fill doesn’t stand up to the fuel dilution and/or will lose viscosity for other reasons relatively quickly in these turbocharged engines. Mobil 1 ESP 0w30 would be a good choice. I’m trying Valvoline Restore and Protect and HPL in my two Broncos. I’ve seen good UOA results on another forum with PUP 0W-40 on this engine, but it was just one UOA.
Several of us are using the Fram FE11955 synthetic endurance cartridge oil filters which seem to hold up well and have good filtering efficiency at ~20 microns (99%). I believe the Fram Ultra is the same but a little more expensive, or try a carquest premium. I think the oil life monitor uses 10,000 miles or 1 year, whichever is closer, so it probably says 55% due to time in your case (oil filled ~7 months ago).
I doubt the oil is anywhere near used up, but the filter by 1000 miles probably has some metal in it. You could cut it open and see whats in there. Then maybe run it another 1k, and see what the second filter has captured There are people that don't bother doing any changes above and beyond what the manual calls for. And they still get a couple hundred thou out of their cars. Whatever floats your boat.,,
I would not reuse the filter after cutting it open.
When I bought my 2022 GMC I changed the oil at around 1k miles as a pre-caution. I was pleasantly disappointed to see that nothing bad was in the oil or filter (cartridge style). Total waste of time and money, other than the peace of mind that the engine had no visible debris in it. Very strange feeling.
So my vote is to let it ride. Not only because it will be a waste of time and energy, but also to avoid the anxiety if something was found. What if you notice the tiniest shiny metallic speck in the oil? For me, that would ruin the road trip. I'd be internally panicking about something that is likely meaningless.
Enjoy your trip!
Back and put just over 3k miles on it during our trip. Back and have a question: what are the chances I’ll need to replace the drain plug? Thst’s the only thing I don’t have atm.
