4WD
$50 site donor 2025
Did you see the filter Wayne posted?A total waste. Not much money but still a 100% waste. I've cut apart many filters and never seen a speck of dirt or debris. You could argue about an oil change.
That’s the key - the debris flush and initial break in is done by 1k … it’s all slow motion after that … Is it needed? Who knows - but my last vehicle to use oil was a 79 PowerWagon at the valve stems …How hard is an oil change on this thing?
If the filter has break in material, so does the oil. Get all of that out early, or just ride it out until the OLM tells you.
They have 4 2024's near me at 20000 off.I wouldn’t bother unless changing the oil. How do you like the Bronco? I’m looking at one for my wife, a Badlands, Sasquatch, 4DR with black painted hardtop.
I’m pushing for a Bronco Raptor but she’s not having it.
Hard to tell what’s needed or not. This is more of a precaution IMO. There could be lots of material floating in there or very little. Could be big chunks, or small.That’s the key - the debris flush and initial break in is done by 1k … it’s all slow motion after that … Is it needed? Who knows - but my last vehicle to use oil was a 79 PowerWagon at the valve stems …
No. How about a link.Did you see the filter Wayne posted?
I changed-out the oil & filter in both my Audis (purchased new) @ 1k miles. Since your oil filter is "on top", go buy an oil extractor, extract the oil, change the filter, and refill with new oil. You'll be done in a 1/2 hr. (tops). I perform oil and filter changes every 5k miles on my 2 Audis - both have cartridge filters in screw-on filter housings located in the "hot-V".Thanks for all the suggestions. I’ve decided to wait until I get back.
