Is all this really necessary? Assuming a temp delta of 120 degrees and a Toyota trans fluid change volume of 3.2 quarts yields about 4.8 oz. difference between room temp and hot trans fluid volume. Unless you are so precise that you're changing fluid using an eye dropper, this is way overthinking. Are new generation transmission this sensitive to fluid volume (I'm assuming published Dexron thermal properties as being representative and 3.2 quarts change volume as stated from a previous post)? I really would like to know.
I believe a more typical change volume is probably more like 10 quarts. In this case, the volume difference would be about 15 oz- less than 1/2 a quart. Would this make any difference in trans performance?
