Originally Posted By: JohnnyJohnson
I see we don't have a lot of firewood cutters here.
Let's see, I'm a founding member of the Bothe Forest Practices Group who have responsibility for 1,800 acres of public park lands and clearing trails, removing hazard trees maintaining forest health etc. We do about 30~40 trees a year.
I also cut on our ranch property and do a few cords of fire wood a year. Plus I have a modest chain saw collection housed at the Park for historic saws and some good running modern ones at home. Smallest is a 12v Royobi battery saw with 6" bar and largest is a 100cc Partner with 36" bar slinging a .058 chisel skip chain.
I have a 120v Royobi electric with a real oil tank and gear driven oil pump with 16" bar that runs well and has cut many cords of fire wood when there is power available. The trick to 120v saws is to use a large enough extension cord... They need 12 amps (or more), so you need a #12 wire cord if more than say 30' from the outlet, like say 100' cord or something. Run light winter bar oil with 120v electrics.
A 36v Makita electric battery saw has the same chain speed as most gas saws. For casual cutting and trimming, there is no reason to use anything else. They will swing a 14" bar and cut up to 10" material quite well. If you already have 18v Makita tools, they are no-brainer as they share batteries (2) so it's all good
IF you like 2-stroke gas tools (?), then by all means get a Stihl or a Husqvarna. Get it from a reputable dealer and they will service it for many years if need be. But they are fuel picky, don't like alcohol in gas and will need attention from time to time ...
I have built the odd race saw from time to time. Usually smaller class saws like 75cc or 50cc that turn right up there at 11~14,000 RPM and will CUT
But they are finicky beasts and they WILL seize. I don't care how much, or what oil you use. They just get to hot, to quick. I've built them on Poulan, Husky, and Dolmar. There are ways to make any brand work ...
If you want a store bought gas saw and you don't have a good dealer close buy (?), Tractor Supply Company (TSC Stores) has Jonsered saws which are part of Husqvarna and run pretty good. They are tough for modern plastic saws ... And any Husky shop can work on them, if need be
But if just casual work - electric is fine
Just get a good one. A cheapie will frustrate you to death ...
