Anyone install a bypass filter setup? I was thinking of putting one on my '94 BMW 540i. It currently has the oem cartridge style filter and I run Amsiol 10w40 in it. Just wonder how big a project it really is since few people I know do it.
Reminds me of the Consumer Reports test on synthetics in taxicabs. In both cases, same weakness: taxis run all day. They start and stop the engine much less frequently than other cars and thus incur less wear, so it's difficult to draw conclusions on wear protection from taxis.quote:
Originally posted by Steve S:
Amsoil did a test on taxi cabs and the results did not seem worth it.
You can put a single remote bypass system if your FF filter is special. You just have to find the oil sender unit and branch off of it with a T fitting to the bypass and back to a non-pressure source like Oil Pan, Oil fill, or valve cover. I recommend Oil pan in a location higher than the plug. Some cars don't like to have oil put down the oil fill or in the valve cover especially at high rpms, so i dont recommend it.quote:
You're recommending bypass filters?quote:
Originally posted by Therion:
My recommendation is go with a Motor Guard filter they offer the best filtration
Have you seen a car with a cartridge filter setup?? It's engineered to the car, usually up on top of the engine. It would be near impossible to put a FF filter on this.quote:
Originally posted by therion:
On the other hand it will be much easier if you figure out a way to mount a regular FF filter and use the a set-up where you have an adapter that goes where your old filter was and makes 2 filters (FF and bypass), although requires more room it is much easier to install and remove. My recommendation is go with a Motor Guard filter they offer the best filtration
We are all here for the same reason to gain knowledgequote:
BTW your recommendation of the Motor Guard, what experience do you have with this to make the recommendation??? Just wondering becuase it seems that you have just started looking for the filter and have been waffling between several models. I can understand Ralf making the recommendation as he uses them and has a lot of experience with by-pass filteration. I might not agree with everything that he says but I do think we are in the same boat, I'm just at the Bow and he is at the stern LOL
quote:
On 1/25 Therion wrote:
I agree the TP idea is good. But what i dont understand is how does the TP not fall apart and get peices of paper in your oil??
quote:
On 1/26, Therion wrote:
And then theres the concept that the TP traps dirt better than the wooden element in amsoil...
A week ago, you didn't even know what a sandwich adapter was. I really appreciate the opinions of knowledgeable people on this site, and there are some people out there that like to criticize us for some outlandish opinions. Your "research" appears to be based primarily on the opinions of others.quote:
On 1/27, Therion wrote:
The single mount bypass is complicated, and very dangerous....
Ok sorry for posting garbage. You are right, i should intall my Motor Guard before i say it is good or talk smack- which will be next weekquote:
Originally posted by slalom44:
Maybe it would be a good idea for you to gain some experience and learn from the experiences of others before you offer advice based on the opinions of others, Therion.
Ralph can say there is no better filter media than cellulose, and his experience and knowledge on the subject makes him a credible source. When you say cellulose "is the best lube filter known to man", I just cringe. Here are some of your comments in the past week:
You seem like a smart guy, and you seem eager to learn. You may want to use a little discretion on your posts so that others view your comments as contributions, rather than garbage.
