Originally Posted By: Ethan1
You can't break a fluid
Originally Posted By: THafeez
My favorite fluid on breaks is water you should try it
2x, I've never hear of fluid breaking either.
On a serious note, my 2014 Mazda 3 has the brake fluid and clutch fluid in one container. When I changed the Lube at around 30k miles or so, the clutch pedal certainly felt better and more engaging then before.
You won't feel any difference in braking power with a fluid change. You'll feel a difference if say you took the car to the track and start noticing major brake fade after a few laps on old fluid vs going around for 2-3x more laps on new fluid with proper, in spec boiling point. THAT is where the difference is.
