Based on?It might be a calibrated electric oil pump drive gear.
You're way too serious. An electric pump with a drive gearBased on?
Hopefully they have dealt with the biggest gripe I have with my 2020, the injectors are noisier than the engine on tickover, which wouldn’t be hard as the B58 is whisper quiet.There are fairly large differences between B58, B58 TU, and B58 TU2. However, I agree that it's almost impossible the oil level sensor cares about viscosity. It doesn't even seem possible.
Based on him making it up….Based on?
Of course not. Probably the the goofiest "my car detects the wrong grade" notions we've seen.All cars that I know of with this feature use oil level sensors, so they are simply incapable of measuring viscosity. I've seen ultrasonic / acoustic viscosity sensors in another industry but they were very expensive and it would be tricky to use them in a meaningful way for PCMO. The technician probably hit the wrong button on the dispenser and overfilled the engine.
Yeah, grade sensors are simply not practical.Of course not. Probably the the goofiest "my car detects the wrong grade" notions we've seen.
Goes along with the electric oil pumps and sheared drive pinions.
BMW OLM computes primarily driving data. Rpm’s, miles, etc.Yeah, grade sensors are simply not practical.
But, estimating contaminants to judge the need to change an oil is possible. Some BMW sensors measure a dielectric current of the oil and compare it to a dielectric constant to determine the contamination of the oil...but, viscosity is a bridge too far.
That said, my BMW engine oil level sensor seems accurate enough. OR, perhaps it's simply stuck at FULL and I'm lucky to not be burning a significant amount. I put 5.25 quarts in, it reads FULL, and 5000 miles later, I drain 5.1 quarts out, when it is still reading FULL. I don't squeeze the filter media dry...that's where the 0.15 missing volume must be. B-)
Didn't know that! I must admit, I like checking the oil level physically...but, I'm old.On top of that, N63 is back with dipstick.
Yeah. BMW mechanics were making pressure bcs. it takes time to do oil consumption diagnostics etc.Didn't know that! I must admit, I like checking the oil level physically...but, I'm old.
