Did a battery replacement on a 2009 Subaru, original battery was getting weak.
I put a memory setting saver powered by a 9 volt it the cigar lighter.
I turned the key to accessories,the light on the saver came on.
Left the key in the accessories position and removed the battery.
At this point I checked for voltage at the battery terminals with a DMM, no reading.
I thought I should have had 9 volts here.
Installed new battery and turned the key off and unplugged the memory saver.
Started the car and found that all my radio presets were gone and the
gas pedal/throttle felt soft.
Why weren't my settings saved?
