The car is 1995 Toyota Tercel with 293K miles. I have installed a Frantz oil bypass filter 6K miles ago, and replaced the toilet paper roll every 1K miles with 1 quart of fresh oil and full flow oil filter every 3K miles. I haven't done a full oil drain since the installation of oil bypass filter. The oil used is Mobil 5000. The engine does burn oil about 1/2 quart per 1K miles.
I bought the car last May with 275K miles on the original engine. The previous owner did not change the oil frequently enough (sometimes as long as 5K miles) since this particular engine is known for being a oil burner. As I poked around the inside of valve cover thru the PCV hole, I noticed the presence of grimes. Here are my questions:
1) Will Auto-Rx clean the inside of valve cover and the head?
2) Do I have to do a full oil drain first before starting the Auto-Rx treatment? Right now my full flow oil filter has another 1K miles of life to go. My toilet paper roll needs replacement now. The oil still looks golden honey. Should I replace the toilet paper roll now and add a quart of fresh oil to drive another 1 K miles, and then do a full oil drain with a fresh full flow oil filter prior the Auto-Rx treatment?
3) Once the Auto-Rx treatment is started, would you recommend not to replace the toilet paper roll every 1K miles but wait till 3K miles later to do a full drain? I understand that Auto-Rx won't be filtered out by the bypass filter.
Thanks.
Thanks.
