Originally Posted by WhizkidTN
Originally Posted by donnyj08
I think it boils down to fuel dilution and low quality lubes mostly. People have been told that cars don't need oil changes as often, which was true pre GDI-TGDI. What most don't realize outside of forums like these is that running 7.5k-10k OCI on the cheapest dealer fill is disastrous for modern GDI engines.
Guys like Wemay use premium lubes every 3-5k and get excellent results.
If everyone ran something with a MB229.5 or 229.51 spec or even a way less stringent A5/B5 spec we wouldn't see the issues at those longer intervals, however most people are buying the $29.99 whatever the dealer puts in and driving 7-10k miles without ever checking the dipstick.
Check out this UOA on a KIA where a dealer is using garbage oil. Imagine this oil being ran 2 times longer than it was...bearing wear would continue to increase.
Recent KIA UOA Posted
I too was one of those that did excellent maintenance of my '12 Turbo Kia Optima. My engine got regular UOAs from both Blackstone and Polaris and I never used a drop of oil. I always did an OCI of ~4K miles and always ran 0W-40 oil (first with M1 Euro and then due to experiments with Castrol Edge Euro, I now run Castrol Edge) and used high quality filters (been running the Fram XG9688 for several years). So I too thought I'd be one of the "lucky ones" to avoid the "rod knock of death". Guess what - I wasn't.
So while very good maintenance IS very important with this engine (T-GDI), the design weakness of apparently the oil pump/balance shaft assembly (it binds up and pumps less oil resulting in rod bearing issues) was the real enemy of many of these Kia/Hyundai engines. They DID resolve it with a new design and all the replacement engines have this improved version (along with improved pistons and rods which proved a bit weak in the early turbo engines). I did get these when I got my new long-block replacement engine back in Dec '18 (totally free). So as I've said before, I'm a very happy camper.
This is an excellent, sobering post. I've mentioned it before, the type of oil will not matter if you are one of the unlucky ones. It's the oil level that matters with this engine. It must be checked every so often. I do so every fuel fill. I'm glad they took care of it for you and you're happy with the end results.
