Originally Posted by JamesBond
No penetrating oil will work on these, the threads are already sitting in oil. When I drain the atf or mtf on my hondas I use a 3/8 in breaker bar and a rubber mallet to strike it. You might be able to use the mallet on the 3/8 ratchet but sometimes these ratchets are still kind of short and also hammering on them could break them.
Originally Posted by SLO_Town
...... the drain plug looks like one of those broad shouldered ones that has a o-ring underneath the shoulder of the bolt head. It's been my experience that these plugs can be very difficult to remove, even when they are torqued to spec. Scott
This is why it is useless to apply any type of penetrating oil on this type of plug. 1.) As mentioned, the threads are already sitting in oil. 2.) That plug has an O-Ring seated in a flange to seal it. So no penetrating oil you apply will ever get to the threads from the outside. The O-Ring itself will prevent it.
Get the best fitting and longest breaker bar you can find, then put yourself SAFELY in the best position you can get yourself into in order to administer maximum torque, and something will give. Just hope it's the plug. (From your picture that casting already looks cracked on the left side going to the plug).
