ET.You're right. Doesn't look like a lot of damage. Hood looks repairable. Bumper might polish out or just need repainting.
As for the green colour, wouldn't you just paint the parts?
DD,This is my ideal rebuildable, a light hit with bolt on parts, older/low value and generally undesirable car. It'll be interesting to see what it sells for, from what I've seen they are going for too much once you factor in fees and the hassle.
Trav,Clean and an easy fix. Have you ever thought about learning to paint?
With today's modern paints if you wait for a no wind low humidity day you can do small stuff like a hood or bumper cover in a normal garage or even outside (low wind). Sure if you paint daily you are going to be good at applying it, its the prep work those guys don't doTrav,
Yes I have thought about learning to paint. I have so many projects going on, just have left learning to paint/ setting up a paint booth have just seemed to be something I should pass on.
One a funny note, as a teenager I worked in a warehouse next door to a very high end body shop. The body shop's owner was a perfectionist. One comment he planted in my mind, was that the painters at Earl Schieb were among the best. His theory was the Earl Schieb painters sprayed 20 plus cars a day. The 20 plus cars a day enable these painters to get good at spraying, etc.
that can spoil the job as well as low end materials.
Renowned as one of the greatest car builder and possibly the best painters in this business Gene Winfield paints this job in an old garage for someone.
