The louvers look good. Thank You for great photosFrom my 2013 Suburban 1500 5.3L with 146,400 miles. In service for 7,000 miles and 5 months with Mobil 1 0w-40 FS (SN). Replaced with an Amsoil EaO17 and Mobil 1 0w-40 FS (SP).
View attachment 188137View attachment 188138View attachment 188139View attachment 188140View attachment 188141View attachment 188142View attachment 188143View attachment 188144View attachment 188145
Good run. The oil does appear to be a fairly good dark color on this 7k run. What oil did you use for this filter? You plan to stick w/7k intervals?
EDIT: Just seen that you used Mobil 0w-40 SN on this run & then replaced it with the latest SP version.
Color of the oil indicates nothing about its ability to protect, nor where in its lifespan it is. That’s the stuff a UOA is properly equipped to tell you. Viscosity, TBN, fuel %, etc.Good run. The oil does appear to be a fairly good dark color on this 7k run. What oil did you use for this filter? You plan to stick w/7k intervals?
And where did I say it did?Color of the oil indicates nothing about its ability to protect, nor where in its lifespan it is. That’s the stuff a UOA is properly equipped to tell you. Viscosity, TBN, fuel %, etc.
You didn’t, but I’ve been here long enough to see members make a big deal of dirty oil in filter. Don’t let it bother ya JustinAnd where did I say it did?
That certainly seems to imply that the color matters. If not, I’m glad you’ve already learned that from this site.Good run. The oil does appear to be a fairly good dark color on this 7k run. What oil did you use for this filter? You plan to stick w/7k intervals?
Seems to me it was just an observational statement that was neutral in context. I didn't learn about oil color from this site.That certainly seems to imply that the color matters. If not, I’m glad you’ve already learned that from this site.
Always had a startup rattle when I use those on two different carsFrom my 2013 Suburban 1500 5.3L with 146,400 miles. In service for 7,000 miles and 5 months with Mobil 1 0w-40 FS (SN). Replaced with an Amsoil EaO17 and Mobil 1 0w-40 FS (SP).
who manufactures the filters for Amsoil anyway? Champ or someone else?Oh, the horror of leaf springs ... I remember the days on BITOG when people would just cringe unless a filter used a coil spring. If this were a Fram EG, people would decry its use. But put a leaf spring in a premium Amsoil filter and no one notices. Brand bias at its best.
All that aside, the filter looks great. But it should, considering both the lube and the filter are way under-utilized.
Champwho manufactures the filters for Amsoil anyway? Champ or someone else?
Looks, and sounds, like the M1 FS 0W-40 has been doing some cleaning. What oil was used prior?
