Originally Posted by rollinpete
Originally Posted by JustVehicleInq1
Oxygen concentrators produce medical-use oxygen applying Zeolites (under pressure) to extract oxygen from the air.
An Indonesian University had studied how Zeolite engine air-filters boost oxygen, and influence engine performance. LINK: University of Lampung study:
https://zeolitalamlampungunila.wordpress.com/tag/air-filter/
Right-click, and scroll-down to and click - 'Translate to English.'
UTILIZATION OF LAMPUNG NATURAL ZEOLITE AS AN ENVIRONMENTALLY FRIENDLY AIR BURNING ADSORBENT TO IMPROVE THE PERFORMANCE OF 4-STEP GASOLINE MOTOR VEHICLES
June 1, 2009, 2:50 pm
Filed under: Journal | Tags: Activated zeolite , water filter , Nitrogen removal , Oxygen-rich combustion
By: Harry Wardono, Ir. M.Sc.
Research Institute
Created: 2008-01-03, with 1 file (s).
Keywords: Oxygen-rich combustion, Activated zeolite, Nitrogen removal, air filter,
adsorption by zeolite.
Subject: oooooooooo
Call Number: oooooooo
References click here or
http://digilib.unila.ac.id/go.php?id=laptunilapp-gdl-res-2008-harrywardo-1172
SUMMARY
Indonesia. The use of zeolite as an air adsorbent to produce air with high oxygen concentration has long been and has been carried out a lot, even now it continues to be developed. However, the application on the fuel motor is still very lacking, only limited to reducing vehicle exhaust emissions. Motorized air filters are only capable of filtering coarse particles, while natural zeolites can capture molecular / angstrom-sized particles (such as nitrogen, water vapor). By putting natural zeolite before the air filter, Wardono H. (2005a, and 2005b) has proven the ability of Lampung natural zeolite to improve fuel motor performance in the laboratory (5.68% crank power, and 8.03% fuel saving). However, so that these zeolites can be commercialized, further research is needed on moving motors (carburetor cars). Tests were carried out using 3 sizes of zeolite (1.5; 2; and 2.5 mm), 3 variations of zeolite packaging (full, half, and separate packaging), and 4 variations in the number of zeolites (100, 200, 300, and 400 grams) . The engine performance test is directed at the gasoline consumption test (the car moves on the highway and stationary) and acceleration test (0-100 km / h and 70-100 km / h), the ability of pure natural zeolite from Lampung to reduce carburetor car fuel consumption has been proven through this research. The size of zeolite has an effect on decreasing fuel consumption, where the smaller the size causes a more efficient engine operation. In addition, more zeolites provide higher fuel savings in half packages and separate packaging,
Whereas in full packaging it did not occur, the highest savings occurred in the use of 200 ml of zeolite. The highest savings that occur in the use of these three packages are 29.35 ml (12.67%), 21.67 ml (9.35%) and 20.07 ml (8.66%) for full packaging, half packaging, and separate packaging, respectively. On the other hand, the ability to increase acceleration (0-100 km / h and 70-100 km / h) from the three packages is not much different. At acceleration of 0-100 km / h, car acceleration can be increased up to 3.07%, while acceleration of 70-100 km / h increases by 12.59% Half packaging dominates the increase in acceleration.
Activation of Zeolite can reduce gasoline consumption higher than that
natural zeolite. The best results occurred in the use of 200 ml zeolite, which was able to reduce gasoline consumption by 61.66 ml (23.87%) for physical acid zeolite activation, and by 60 ml (23.23%) for base-physical zeolite. While the use of 300 ml of zeolite obtained a decrease of 41 ml (15.87%) and 34.66 ml (13.42%) for zeolite acid-isic and base-physical activation, respectively. In another test, in the acceleration test it was seen that zeolite base-physical activation was more dominant than zeolite acid-physical activation. The use of zeolite with an amount of 100 ml and 200 ml gave an increase in acceleration which was far better than 300 ml of zeolite.
The highest increase in acceleration occurred in the use of 200 ml of zeolite, which amounted to 2.99 seconds (7.89%) for zeolite acid-physical activation, and was 3.83 seconds (10.10%) for zeolite base-physical activation.
This zeolite activation ability to save gasoline seems to be fluctuating
day by day. Lastly on the 14th and 15th day the ability of basafisic zeolite activation has been reduced to 7.8%, while the ability of zeolite acid-physical activation has been 8.5%. Based on the results that have been obtained, up to the 15th day the ability of these two zeolite activations has halved.
Thus, it is estimated that the effective age of these two zeolite activation is one month. On the other hand, towards the 9th and 10th day the zeolite acceleration ability of base-physical activation has also been reduced (to 2.9% and 9.13%), and to 1.92% and 8.69% for zeolite activation acid-physical. Furthermore, on the 12th and 13th day the acceleration ability of these two zeolites activated decreased to below 5%.
I read it but don't know what it means.
I wonder what kind of dressing they put on that word salad.......
