I recently installed a Weber conversion kit on my old Toyota pickup. The filters they come with are small and look similar to a K&N. I work in a pretty dusty area, so I'm not convinced that's the best type of filter for my use. Weber makes an adapter plate that you can install a standard Holley-type air cleaner to the carburetor, so I'm thinking about doing that and ordering a standard round air cleaner assembly for it.
What size is the most common, and how tall should it be? I was looking at a round filter that was 2" tall, but I can't remember the model. Wix's website said it was rated to flow 192 CFM. The Weber and OE carburetor are both rated right at about 325CFM. Do I need to find a taller filter for it?
