spasm3
Originally Posted By: Trav
Originally Posted By: spasm3
i have one bolt i can't get my aircat on, I am going to get a two piece universal. AAARRGGH !
Which Aircat? Don't use a full size or even the mini gun on these bolts, I use a little 1/4 variable cordless impact driver and let them lightly "rattle out" if they don't zip right out. I am surprised you didn't take the heads off more of them.
Use hand tools working them back and forth with penetrating oil on the threads from above on the exposed ones to remove them if you don't have a small impact driver.
Aircat 1150 i did wring 2 off the mid section where the two manifold pipes come together. the front drivers manifold is off. I had to use a propane torch and get it good and hot, none of them broke. I'm letting the passenger side soak in penetrant overnight. I tried with 1/2 sockets and a 2ft breaker bar and could not budge them, that's when i broke out the aircat. I'll let the passenger side bolts soak overnight and if i get home early enough, i'll heat them and hit them with the aircat, maybe i'll turn down the pressure a bit at first.
Thanks for all your advice Trav!!
