- Joined
- Oct 20, 2023
- Messages
- 47
Do anyone know why when I put D in my shifter, rpm's slow down a little bit and then recover? I already cleaned the throttle body and IAC and this is the same. Anything that I am missing? Thanks
seems to me that every fuel injected car in the world does something similar that . you missing nothing as long as its a minor drop. if it just about stalls you have other issuesDo anyone know why when I put D in my shifter, rpm's slow down a little bit and then recover? I already cleaned the throttle body and IAC and this is the same. Anything that I am missing? Thanks
Ok thanks, how many rpm's down is normal? cause it feels like it is going to turn off, but just after that recovers the rpm'sseems to me that every fuel injected car in the world does something similar that . you missing nothing as long as its a minor drop. if it just about stalls you have other issues
OK thanksThat's normal, the tq adds engine load then it accounts for it. every vehicle i have does that, same with my 2021.
50-150 just a small amount. cleaning the iac never has seemed to work for me id just replace it personally they are cheap for the 4.6Ok thanks, how many rpm's down is normal? cause it feels like it is going to turn off, but just after that recovers the rpm's
Ok, thanks.50-150 just a small amount. cleaning the iac never has seemed to work for me id just replace it personally they are cheap for the 4.6
where I can find original parts?Totally normal. Dont waste your money parts you dont need. Original Ford parts are better than most junk they sell these days.
Look for the Motorcraft brand.where I can find original parts?
Do you have a recommended website for this?Look for the Motorcraft brand.
What year are we talking? Once they went TBW I thought there was no IAC.
If he's TBW then OP should wipe the memory by discharging w a jumper wire and let it relearn throttle trims as he says he cleaned the tb.
You are taking a chance by removing the positive lead before first removing the negative. If your goal is to reset the computer, you can accompish the same thing by removing the negative lead.Grand Marquis LS 98, I just removed the positive of the battery and after 5 minutes I installed again, no problem with that. Or this procedure is required?
rockauto.comDo you have a recommended website for this?
ok, thanksYou are taking a chance by removing the positive lead before first removing the negative. If your goal is to reset the computer, you can accompish the same thing by removing the negative lead.
ok, I know this place. Thanksrockauto.com
