Originally Posted By: JLTD
Originally Posted By: clinebarger
3.55:1 means for every single revolution of the drive shaft.....The axles will turn 3.55 revolutions.
Sorry, sir, but you have that relationship backwards....the drive shaft turns 3.55 revolutions while the axle turns once. Big difference between the two!
FWIW OP, I had an 80s Mustang with the 5.0, went from 3.21 to 3.55 and it was not astoundingly different, but did liven up the car. You'll notice a difference initially.
Are you saying that tiny pinion spins faster than that huge ring ?
So, in all this I’m still lost for intents & purposes for an expensive swap on an older truck. Just to change it a bit … new plans for truck … are many of the current parts worn out … etc
I do like 3.73 ~ most of my past 1500’s had that … but my smaller Canyon has 4.10 and does not need it with the 5.3L … and does not get the MPG it could … 3,73 is a good (compromise) ratio …
