Originally Posted By: Miller88
I'm okay with CVT only. Subaru's CVTs have proven to be reliable.
If anybody is looking at used Forester XTs with CVTs, this info might be of interest...
"This Service Information announcement provides information regarding three new production enhancements to the CVT transmission (model TR690) used in the Forester model with 2.0L DIT (Direct Injection Turbo) engine:
•An in-line CVT fluid filter has been added to reduce the possibility of contamination entering the lock-up circuit of the valve body
•Machining of an existing fluid passage in the transmission case to accept the new filter
•A smaller corresponding port on the mating surface of the valve body along with a sealing o-ring was added to retain the filter in the transmission case.
COUNTERMEASURE IN PRODUCTION
The revised valve body was incorporated into production 9/17/2013 with transmission #631685.
All three of the changes listed above were incorporated into production 9/21/2013 starting with VIN E*503139 and transmission #632523."
My '14 didn't get the filter and I just had the valve body replaced about a month ago. There is no way to retrofit the filter into the older transmissions and I guess I will only have one if I end up needing a totally new transmission. I guess I made it 80kmiles without an issue, if I can get to 160k before it comes up again I will probably be sick of the car and maybe could sell it to somebody looking to stuff a 6MT into it.
I guess I'm still ahead of my '06 RAV4 on repair history, that needed a ~$3500 AWD system repair just past going out of warranty at 60kmiles. The CVT valve body replacement was covered under an extended 10 year/100kmile warranty that Subaru provided for 1.5 million 2010-2015 vehicles.
