Originally Posted by Astro_Guy
Originally Posted by PWMDMD
Do you honestly believe there is any meaningful difference running any of these oils in a Honda V6? I changed it just to flush the engine one more time, have a buttload of 5W-30 PP and I just happened to be at 20K so it's easy to remember 5k OCIs.
You are introducing new variables at each OCI. If the wear metals improve dramatically on the next UOA, you won't know if it was due to the oil or the fact that maybe the engine is finally broken in.
The wear metals either are or aren't going to come down and I think it has little to do with which oil is used. It may have something to do with the volume of oil that goes through the engine and if this is the case I should be seeing a reduction soon. If wear metals do not come down eventually the only thing that makes sense is there is some problem with the engine - a problem that will not be helped by any specific type of oil or any volume of oil.
