2017 Honda Civic 1.5T, factory fill, 2977miles
Michigan
I'm posting this for a friend of mine who has a 2017 Civic Hatch with the 1.5T engine. I know I've been lurking but reading a lot about fuel dilution because of the Direct Injection design. I know with their car you could start to smell whiffs of a gasoline smell as they got closer to 3k miles.
I told them (based on what I was seeing plus this website's guidance, thanks) that they should get the oil changed and send it in for a lab analysis. Sure enough Blackstone did find 1.5% fuel, but as we know they don't have the accurate gas chromatography that Polaris does. Next sample I'll have them send it there.
They refilled with Honda's branded 0w20 full synthetic. I think ConocoPhillips makes that.
But for now, feel free to give me input of what you think.
I know I was surprised how quickly it's out of 0w20 spec for viscosity!
Good call on early change. Still looks good though and im sure the 0w20 would be fine for longer intervals once car is broken in.
Originally Posted By: ChiTDI
At what time/mileage did Honda say to drain the factory fill?
I don't know if the new Civic engine is any different but Honda says oil should be changed when oil monitor reaches 5%-!0%.
Seems Honda uses a break in oil for rings or whatever.
was
That stated,the changed on a '08 Civic at 2500 miles my son owned.I was told the engine would blow up.
The car didn't have any issues when it was sold at 110K miles.
Another report with severe fuel dilution (even though the numbers are good but you can tell by viscosity). Metals looks very similar to mine at 4700. Have you noticed how much you were able to drain (volume wise)? Have you been noticing increase on oil dipstick? What highway/city combination on this oil and did you practice gas saving or spiritual driving?
Originally Posted By: Nickdfresh
Interesting that the fuel dilution isn't bad at all...
The dilution is bad. Often Blackstone reports none or trace even when the real result is over 5%. For them to report a number at all, it has to be bad. They shouldn't even list fuel on their report as they don't measure it even close to accurately. Many owners of this model are going to 3k oil changes because of the severe dilution.
The fuel dilution could get better as break-in completes and the rings are fully-seated. Nonetheless, this seems to be a troublesome characteristic of this engine (I think we've seen 4 or so UOAs here and they all show the problem) and a long-term short OCI strategy may be in order. I think a Polaris UOA would be a good idea: if it shows significant dilution take it to the dealer to at least document the issue.
Thanks! I had a feeling it was time when my friend started to smell gas fumes.
Honda goes by a maintenance minder, and there is NO WAY that the oil would last til that indicator comes on (usually around 7000+ miles on average)
Don't ya love those "scare tactics"?? They've shown that Honda stopped using the "magic break in oil" a long time ago. I don't listen about manufacturer stuff like that either.
I was comparing this oil analysis with yours, actually! Yours was very similar to this, so at least we know that Honda knows how to build an engine. I have asked my friend to keep an eye on the dipstick to see if volume is increasing, he didn't ask the technician when it was drained.
This is 60% highway and 40% city, nothing crazy, just some quick sprints up to highway speed, but nothing like hard driving or driving like ya stole it.
I completely agree, if Blackstone reports fuel dilution it's usually higher than that. Polaris labs is who Oil Analyzers uses, and they do have a gas chromatography tester that can report fuel dilution more accurately. I agree I think 3k is the MAX and even that is pushing it. Look at the viscosity, it's 2 points from min. Ok so it's close, but I sure don't want to be running that thin. I'm thinking somewhere between 2500 and 3000 is when it really needs to be drained/replaced.
The viscosity is way low as is the flash point. Definitely a bad diluter. Shorten your OCI.
I completely agree with you! Sad that this is only at 2977 (3000 basically) and the oil is that far gone! And this is full synthetic!
you bring up exactly what I was thinking Danh! I think it was either here or civicx forum where as time went on the fuel dilution actually went down. Since direct injection engines have such high pressure fuel injectors then once the rings seat-in, then I'm hoping (For my friend's sake) that the dilution goes way down.
I am planning on having my friend sent it into Polaris next time around. But document with the dealer, he could, but I'm thinking that with all these people having the same exact issue, it would be a massive recall. I can't believe Honda's engineers would miss this in the lab.
I have looked at the conocophillips oil that Honda is using.. Which is what I had my friend put back in on this first oil change. Actually they spun it off into Phillips66 brand oil. And from what I saw their 0w20 full synthetic is on the thicker side of any 0w20 I've seen so far. I didn't try anything else right now as I can't find anything as thick as what Honda is using for a 0w20 full syn. I keep wondering if I'm wrong in thinking a thicker grade oil could be used since it's going to be thinned out quickly anyway. I'm not recommending anything to my friend as he isn't the car guy type. I'm trying to see if shorten the OCI's until it's fully broken in, and then we can see if the fuel dilution lowers. Plus I'm waiting to see what other oils come onto the market that could match what Honda had CP make for them.
I also looked at other oils like a 0w-30 but that isn't even an SN oil, and WAY thicker than even a 5w30. But I'm keeping that option in the back of my mind for now.
I've also noticed that my friend tells me as it gets closer to the time the oil needs changing, there is a faint gas smell from the engine. Went away when the oil was changed. Interesting. Guess this new technology we get to find a new way to handle it..
I don't think Honda's 0w-20 is unusually "thick", at least at operating temperatures. Probably the thickest 0w-20 you can easily find is Castrol Magnatec, which pushes the upper limit for the 20-weight grade at 100C.
Virtually all 0w-30s are SN-rated, Mobil1 being one of them. And 0w-30s are not typically thicker than their 5w-30 counterparts. You can go to any oil maker's website and look for Product Data Sheets (PDS) or Technical Data Sheets (TDS): look at the viscosity at 100C and you'll have a better answer.
was only beginning to look at PP 0w20, and it was 8.3 @100C, while the Phillips66 Shield Armor (most likely what Honda is using in their bottle) was 8.8@100C. Now that you show me the Castrol Magnatec, it's 9.1@100C, wow, yeah much thicker! Thanks for mentioning that!
What was odd was the 0w30's I was finding were thicker than their 5w30 counterparts, I was looking at Castrol Edge when I saw that. I was looking at the TDS's as well. Some of the 0w30's I found were not even API SN rated.. odd. But I'll definitely keep that Magnatec in mind for my friend! Awesome!
I think Honda still does try to "break in" with their factory fill.
Look at the UOA, molybdenum is really high, and manganese ( an abrasive for scoring cylinder walls) is present. Good combo for the first run, but that fuel dilution throws a monkey wrench into that plan.
That's why I asked.
Honda has a really pristine record for engine durability and longevity, hopefully this issue won't change it.
Enjoy the car.
That's why I asked.
Enjoy the car.
I think it's more likely the manganese in the UOA is from an additive in gasoline than something Honda intentionally introduced to help with break-in. Manganese is not used nation-wide but you can also see it in some other fuel-diluters (e.g. Ford EB) long after the factory fill is gone.
That's why I asked.
Enjoy the car.
Thanks for the feedback, you're right the fuel dilution does throw a monkey wrench into the works! Yeah this is my friend's car, I'll pass on the good wishes! I doubt Honda wants their engines to destroy themselves, it's why I'm curious to find out if after 10k miles the fuel dilution problem might correct itself, once things break in. Here's to hoping.
Good point.. I found out from my friend that he had been buying no-name gas from some run down gas station! WOW! He went with Mobil recently and some of the fuel smell he was getting is gone, and his fuel economy has gone up! So with you saying manganese in fuel, is making a lot of sense now!
Oh also wanted to thank you personally, Danh for the info on the castrol magnatec 0w20 oil. I looked into it and mentioned it to my friend, he's sold on it, going to be putting that in on the next oil change, probably next week. This guy drives A LOT! I like how on the EcoBoost engines I saw this magnatec just hung in there and put up with the abuse! Plus found out it's on sale at NAPA right now, which is cheaper than the Honda branded full synthetic that my friend was buying.. So, stout and affordable? What's not to love! Again, thanks!
Ill be the skeptic here (what else is new)
I dont think this UOA is bad at all.
1. Its impossible to gauge anything from a UOA on a factory fill on a brand new engine with 3000 miles on it.
2. Viscosity is not a concern, its not that far out of whack and HONDA knows what takes place with the oil in their engines.
3. Fuel is not a concern, maybe even less of a concern in a direct injection engine.
Too many unknowns and I am willing to bet the unknowns might have more to do with how the oil sample was taken then with the UOA itself.
Many oil samples are incorrectly taken. Oil needs to be up to FULL operating temperatures = ROASTING HOT! This it itself gets rid of much of the fuel in the UOA so you are getting real operating fuel numbers not start up cold oil results.
Ideally it should also be taken from the middle of the drain.
Yes, we are still being told not to do the first oil change early, as it may cause hot spots in the engine bearings.
