Originally Posted by Pew
I wouldn't. There's going to be more issues with rotten seals, bushings, and other suspension parts with age.
I tend to agree, you just can't keep up with the rubber replacement on vehicles as they age, because there's too many pieces, and it's too expensive. People don't realize that once your vehicle reaches a certain age, or a certain mileage, all of those rubber bushings, hoses and gaskets are shot. That front end is in need of serious repair...a control arm here, a set of sway bar bushings, sway bar links, steering rack bushings, the ball joints and tie rods are worn out. Then when you replace all of that? You blow a transmission cooler line, the bottom radiator hose blows, the power steering line let's go, the valve cover gaskets are leaking all over the engine, the oil pan is dripping onto the driveway, the rear main seal is weeping, the oil pressure switch is leaking like a sieve, the thermostat housing gasket is leaking, the rubber grommets for the PCV valve system aren't sealing anymore...or the hose for the PCV valve has collapsed on itself (because it's so weak) and oil is pouring out from every gasket in the entire engine (that happened to me once and that was quite a surprise). And trying getting some of this stuff, you'll go aftermarket because it's cheaper and easier to get...then it won't fit quite right...but you'll make it fit...then six months later you'll be replacing the aftermarket part with something else, probably another aftermarket part because someone will tell you on the Internet that "this one is just like OE", and then you'll spend almost as much as OE, and then it'll fail in six months.
I have taken three vehicles over the 200,000 mile milestone, for the people saying it's a piece of cake...they are forgetting a lot of things. And I can work on this stuff (I'm an ASE master tech). But working on stuff with over 200,000 miles is like putting your finger in the dam while waiting for the other leak to spring.
