Wow what a fun time I had replacing the original rotors and pads all the way around on my 2008 Hyundai Santa Fe @ 69500mi. I don't think all the pads were factory however. I started with the rears since that's all my Carquest had in stock that particular day.
Got some fine white box Chinese rotors and Carquest ceramic pads and a new tube of Sil-Glyde. ~$50/ea for rotors, ~$35 pads. Everything came off great right up to the rear rotors; The little screws that hold the rotors to the hubs came right off with my impact screwdriver, calipers, caliper retaining brackets, no problem. Then I start with the brass mallet beating.. and more beating until I get some wiggle. No joy and it took forever.
I wound up making up some 'jack bolts' to install through the holes in the rear spindles where the caliper retaining brackets go through ('nother tip I found online)to 'push' the rotors off. That worked! Got some wiggle! Now the parking brake shoes are preventing the rotors from pulling off. There is a tiny rubber plug on the face of the rotor to allow you access to the star-wheel adjuster. Yeah right!! It's about the size of a pencil eraser. Had to search online to determine the star-wheel adjuster is at the 7 O'clock position or I would have never found it with all the busted loose rust in there now.
Now the adjuster on the pass side is rusted solid. By the time I got that rotor off I busted a bunch of parking brake hardware. A spring, a couple clips and pins. OH JOY. I called around trying to locate the possibility of a parking brake hardware kit. Napa said they had one in California.. didn't even offer to order it for me. Told me to just call a Hyundai dealer. Carquest said the kit exists and they'd have one by the next day. Out of curiosity I called the dealer. The only way they could sell me p-brake parts is individually. Dude told me last time he pieced one together it was over $100 for a few pins, clips, springs and 2 adjusters!
The Carquest kit was just the ticket. It had everything I needed in one small box for $20.60. Luckily I had some help from my more tallented brother to rebuild the parking brakes. There's SO little room in there tucked between the backing plates and hubs, you need 3 hands to get everything lined up and locked in. Luckily we were able to salvage the p-brake shoes because new ones were ~$60. All in, it was about ~$150 for the complete rear brake job.
About a week later I did the fronts with eBay mail-order Chinese rotors and ceramic pads for $129 all-in. Other option was pay about $65/ea just for new rotors locally. My mail-order stuff was to my door in 2 days. Real nice stuff! No quality issues so far. Thankfully the fronts were REAL easy aside from me breaking my Craftsman 3/8" ratchet trying to break free one of the caliper retaining bracket 17mm bolts. SNAP!! Scared the heck out of me thinking I broke the bolt off in there, until the guts fell out of my 20yr/old trusty ratchet.
My main rants are; 1) Thank you Buffalo for your fine winters! Things shouldn't be that rusty on a 2008 w/ 70Kmi!
2) I truly HATE rear disk brakes. Gimme good old rear drums any day. I'm not a race track driver, nor do I need to tow!
Thanks for listening!
Joel
Joel
