Anyone Familiar with the 2005 era Jeep liberty? Have a chance to pick one up cheap $1800. Wondering if its worth it, and what to look out for.
203k. 3.7L 4wd.
Miles?
Engine? Guessing it's the 3.7 liter?
Maintenance history, if it has one.
Don't remember if there was more than one type of 4wd option that year.
Boss had one and hated it. Vague steering, no power and the window regulators kept breaking, every door, some more than once. Something plastic breaks without warning and the glass falls. That was major headaches, be worth researching.
Comparable examples can be found at the Capital Auto Auction in Manchester which I am sure would go for less than $1800.00.
That mileage just strikes me as too high for their asking price.
Theyre not that bad, we have a couple over 200k and alot in the 160+ range, but they can be sludge monsters, and rusting is always a problem. Does seem high for the price Id be at about 1200 for that, plus have it checked out first so you know whats coing.
I thought all cars were good today, I don't see the issue. Other than rust and mpg, and a few problem models, I thought the BITOG mantra was that all cars go past 200k. Presuming the PO took care of it.
They are ok. Lots of little issues on them usually, not expensive to fix just annoying. Hard on gas. Engine/trans units are ok.
With this kind of mileage though I would pass.
OP states
203k. 3.7L 4wd.
Seems to line up just about right.
Your 'BITOG mantra' crack doesn't hold water here.
200k+ on a 14ish year old FCA product.....
The potential headroom for durability and dependability is likely not that great. Maybe OP will have a great experience with this, but it certainly wouldn't be a first choice here...
I have a 2007 jeep liberty. I wouldn't be scared of it. It has a great 4wd system. Its bad on gas. Reliability is so so, but its simple and parts are cheap.at 15 years all the rubber suspension components are going to be due for replacement
Engine - ok if not overheated and oil changed
Trans- not the longest lasting but its a 4 speed so rebuilts are not crazy expensive
Common issues- window regulators, front acle cv joint
Originally Posted by Chris142
Dont over heat it. The valve seats will fall out of the heads if you do.
I had a 2006 GC with the 4.7. Same as the 3.7 but with 2 more cylinders.
Dropped valve seats at 153,000 miles and it NEVER overheated. I was the original owner. Was great up until that moment.
Personally, I wouldn't take a chance on another one.
