I've been tasked for giving my sisters 2005 honda CR-V a 'once over' whatever that means, to her.
200k miles. I did 2 drain and fills with Honda DW-1 two Xmas's ago on it, and an oil change with a Fram ultra and Pennzoil platinum 5w-20.
She had bought new Centric brake pads for it without evidence it needed them, just that the brakes made noise the first braking in reverse out of her driveway in the morning.
I told her to order some disc brake lube, permatex green or Sylglide, at the same time and any brake hardware kits shown on RockAuto, but neither was in the box of parts when she dropped the car off.
I've only taken off the front drivers side caliper so far. Lower 12mm caliper bolt felt tight the whole way out, had to use ratchet. Upper was finger tight, once loosened, the whole way out.
The inner brake pad is tapered, about 1/8" difference in thickness, front to rear.. The Lower slide pin looks to have one corner pressed in, as if not aligned properly before caliper was reinstalled and lower bolt tightened.
Both pins show signs of wear, and the black grease which was in there, looks more like wheel bearing grease than any brake grease I've ever seen, not that I have huge experience doing brake jobs.
I said i am not reassembling with existing pins and no lube, and I am not running around to local AP stores to get new ones, she can send her boyfriend.
~ 12k miles since I did two DW-1 drain and fills, the fluid is darkish red and not smelling sweet, but not really burnt either.
Magnet on drainplug had less on it than 12k miles ago.
Kind of twiddling my thumbs waiting for new sets of both side front and rear caliper pins to be delivered. Only one jack, I live on other side of country.
The two caliper pins catch a fingernail, look worn in places. I've cleaned out their receptacles with Q tips wetted with silicone spray. Lots of Q tips before they did not turn black. Felt kind of gritty in there.
Wondering what the other 3 calipers look like.
I was reluctant to take on this task, apparently tire kingdom did the brakes ~25 to 30k miles ago. The pads are about half life, if the inner taper would be averaged out. Rotors are not grooved but there is a rusty lip inboard of pad. The rotors have been changed at least once. The phillips head screws are a bit mangled.
