Originally Posted By: Jim 5
Originally Posted By: Chris142
Probly a pretty fresh rebuild. They don't come from GM with FelPro gaskets, a welded oil pickup screen and all steel timing gears.
I agree. Also, if I'm not mistaken, they don't usually stamp the cylinder numbers into the con-rods at the factory. I have seen machine shops do this at rebuild time though. I will confess that I could be wrong about this.
Also, a little bit of a surprise to see a two-bolt main cap in a corvette application. However, as I recall '77 was in the range of the slowest/most detuned years for corvettes...not to mention other american cars.
That would be the L-48 I think is the correct number, engine for that year w/ 2-bolt main. You could get, and I have had the L-82 engine in that year that had the 4 bolt mains. And detuned , yes , but the 4-bolt could be rebuilt to put out more decent numbers, but still not like the earlier years.
Plus the rear end in that car that I had was a 4.11, so set up as a quarter mile racer, the fastest it would go absolute top speed with the 3 speed tranny and that rear end would be about 106 mph.
A friend had one of that year with the L-82 that he had blueprinted and swapped the rear out for hiway gears, might have put in a 4th gear too, can't remember, and would do 140-150 mph cruising easily, not sure what top speed was.
Thing about those cars was at speed the cockpit is noisy! Nothing like a modern car, very little sound dampening, screaming 350 in front of you and [censored] radios/8tracks. What fun.
