3MP,
I'm not surprised by these results at all, when you consider the following factors:
1) It's hard to take a 4 ounce sample that is representative of the bulk oil properties
2) There is a fair amount of variability in these inexpensive lab tests - perhaps +/- 3 ppm in terms of wear metals, and +/- 0.5 in terms of TBN. This is particularly true for determining the TBN as the oil reaches the end of its' service life. For this reason I never go below a TBN of 2.0
3) You only increased the drain interval by 6%, in going from 17k miles to 18k miles. In addition you added some fresh oil after the 17k sample was taken, which affects wear metal concentrations and TBN. This can make it look like the wear metal concentrations are actually decreasing ....
This is why I have argued for sampling only every 3000 miles, so that the trends in wear rates and oil degradation are more apparent. If you look at the results from any two adjecent tests taken 1000 miles apart in your data set, it's hard to tell much of anything.
FWIW, the total solids measurement is clearly in error, unless you somehow totally depleted the detergent/dispersant additives and the solids fell out of suspension. If that had happened, I think you would have seen chunks when you drained the Mobil 1.
I still think it is a very worthwhile test, but you have to take into account both the accuracy and precision of this type of data ....
TS
