Originally Posted By: Gokhan
This has sunk below the lowest intellectual levels witnessed on the Internet. There is no reasoning with you. You turn perfectly valid logical arguments upside down. The concept of logic is nonexistent with you. When there is no logic, all bets are off. I feel like I'm trying to futilely explain things to a five-year-old with behavior problems -- it's hopeless for the logic to prevail.
OK, but if we are attempting to frame ourselves as the bastion of logic, civility and reason then one needs to also consider the exchange, which appears to have started (and I went back through the whole thread) by this relatively harmless comment by nap:
Originally Posted By: nap
Some interesting stuff about humid air. One would expect that humidity improves air's cooling capabilities as now it contains water which has a higher thermal capacity. Well, not really:
https://www.electronics-cooling.com/2003/11/the-thermal-conductivity-of-moist-air/
Which then triggered your first post in this thread which started with this gem:
The guy who wrote this article doesn't understand heat at all.
Now, did you or did you not actually read the linked article before making this comment?
Because that resulted in nap, responding to your condemnation of the author as incompetent:
Yeah right, have you even bothered to google for the author’s credentials? He retired as Principal Scientist at Philips after a career focused on thermal management of electronic systems.
Which doesn't strike me as out of line
To which you replied:
It's good for him. In that case we are talking about your lack of understanding. The fact remains that the effects of air's heat conductivity are insignificant, as the air convection and heat radiation are the primary mechanisms in electronic cooling and air conduction hardly plays a role. You need to understand that part first before you imagine the insignificant effects as being significant.
Immediately deflecting from your questioning of the authors credentials to implying that nap is cognitively hindered and you erroneously what, ascribed the article's contents to nap? Because honestly, his single line and link to the article didn't really leave much in the way of content to be interpreted, which it would seem, was expected to be derived from the body of the linked article, which it seemed initially, is what you condemned.
Things went downhill quickly at that point.
But key here:
You initiated this negative exchange. You could have responded very differently to him, you were not active in this thread before tossing his contribution into a brush fire and slagging the author. When questioned on that you tossed nap into the brush fire instead. If we are going to pretend to be preaching from some moral high ground I think it needs to be said that you were the one that steered this one into the weeds, not nap, regardless of how previous exchanges have panned out between you two.
