Rather than looking at "two points" (not really, but you might get my point), look at the vis v. temp curves of the two or more oils.
Based on what I have learned here so far, you can typically go to the next higher grade without doing any harm to your engine. By doing so, you get better wear protection than you would get with a lower viscosity. Do you need better wear protection? Here's some great info (you've probably already seen or may already be familiar with); skip to the 17:30 mark, and when done with that, skip to the 20:52 mark.
Given that it very rarely drops below +20 deg F where I live, I would be fine switching from the recommended 0W20 to 5W30. I'd get better wear protection and still be good on cold weather starts, while any loss in power of fuel economy would be insignificant.You could do a lot worse than just taking the following general practice:
- Start with the viscosity on the oil fill cap as a reference, go up one one hot grade (i.e. 20 grade to 30 grade). This is fine year round all the time.
- Select the cold (w-grade) needed for your location applicable time period. This could be anything from 0w to 20w depending on where you live.
There are non-viscometric reasons to prefer 0w grades now (better base oils), but that's a separate consideration from viscosity per se.
It's cold here, gets to -60* most winters. 0w isn't that common to sell. One customer runs 0w30 Delo, another 0w40 Penzzoil (fleet if Dodge trucks)If you had to pick one oil, I think vast majority of passenger cars and trucks can be covered with a high HTHS 0w30 and few other Euro approvals (pick your choice) they typically carry ... That'll be as universal as you can get.
0W in case you are living in very cold climates and/or are into more "superior" base oil stuff ... I go with approvals and what's on sale and have been finding more 5Ws in store under that category.
The engineers who design engines are not the ones making the final decisions. Cost of ownership (sales - less maintenance sells cars), financial implications (accounting - to minimize costs), management decisions and government regulations all play a part in what oil is spec'd.
This sums up an engineer's world:
I can’t even imagine how hard it is to start in -60 temperatures with anything higher than a 0w oilIt's cold here, gets to -60* most winters. 0w isn't that common to sell. One customer runs 0w30 Delo, another 0w40 Penzzoil (fleet if Dodge trucks)
Little but of 0w20 for Chevs.
Otherwise most else use 5w, or even 10w.
The diesels, 15w40 is the main one. I'd imagine more due to cost over 5w40 though. It's roughly $6a gallon difference and we're talking shops that use 300+ gallons a week.
I can’t even imagine how hard it is to start in -60 temperatures with anything higher than a 0w oil![]()
When I bought my first brand new car at age 18, it had a block heater as standard (which most Canadian cars did back then actually) I ran 10w30 in that car (1988 Dodge Shadow ES Turbo) and even though I parked it in my warm garage I always used the block heater. Even though the temperature inside that garage probably never went below 50F, I felt that it was beneficial to have my coolant warmed up a bit for the cold starts. Even at 18 years old I knew that the most engine wear occurs in the time period between a cold start and when the engine is up to temperature.It has to be heated. Either block heater or stick a heater under for a few hours.
My oil went on Ozempic - and it didn't tell me till it was too lateOil be thick and oil be thin.
How do it know?
I didn't watch the sketch, but t's not distrust and conspiratorial thinking. It's reality.And here's that distrust and conspiratorial thinking I talked about.
I have the privilege and burden of experiencing firsthand the vast disconnect between what engineering specifies in a perfect world and what comes out in the publications. I've written the publications. I been that engineer. I've seen the politics from the expensive seats.
I'm not arguing that manufacturers specify the very best for their vehicles. I know better than that. But even when the bean counters get involved, the impact of using one fluid/coating/etc... is usually pretty well understood. But they also understand that if they go too low, they'll get too many back under warranty, ruin their reputation, and so forth. Nobody wants that either, just to save a dime here or there.There’s a YouTube vid of an interview with a GM engineer kicking around. He was part of the automatic transmission design team. They developed a planetary gear set with a special coating on some of the gears to withstand abuse very well in hard working trucks. GM decided to literally save pennies per unit and go with non coated gears(but more gears to help compensate). These ended up having a high failure rate per the engineer…but GM deemed it acceptable.
I watched another interview with Torco oil. A performance motorcycle OEM contracted them to design a suspension fluid. The engineers provided them with the specs they wanted and Torco produced an amazing suspension fluid. But after the OEM found out what the cost was decided on a lesser performing version.
So IMO it’s not a conspiracy that engineers have to work within certain parameters that may not be the best, it’s a reality.
