I know very little about oil. I guess my Cu and Fe seem to be steady so whatever is happening, good or bad, is constant, IMO. Hopefully this helps someone else at the very least and I feel I owe it to BITOG members to post my results for all the help, toleration of my stupidity and patience I have been shown here. I am considering going back to GTX at 3-5K OCI. There are bigger things to worry about in life and UOA's aren't one of them anymore. Still, I would appreciate any comments anyone cares to make. Thank you.
BLACKSTONE WRITES:
:There are 70 oil samples in the universal average file for this type engine. You can see that
copper is typically, at least on average, found at about twice the iron level. This is unusual for any gasengine, but there is probably a reasonable explanation for it. Your copper level is improving so at leastsome of it is due to wear-in. The other metals read perfectly after the 4,902 mile oil use run. Our
average oil from this type engine has 5,825 miles on it and there is no doubt you could use thosemiles for your next sample. Even then copper should drop more.
EQUIPMENT MAKE: Honda
EQUIPMENT MODEL: 3.0L V-6
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL: 4,902 Miles
OIL TYPE & GRADE: Mobil 1 5W/20
MAKE-UP OIL ADDED: 0 qts
ADDITIONAL INFO:
COMMENTS UNIT CLIENT all the below M1 5W20
25,204 20,302 14,432 total miles
4,902 5,860 4,252 universal
Al 2 3 2 3
Cr 1 1 1 1
Fe 16 18 12 10
Cu 43 54 37 21
Pb 1 3 1 3
Sn 2 0 1 1
Mo 91 76 91 70
Ni 0 0 0 0
Mn 0 0 0 1
Ag 0 0 0 0
Ti 0 0 0 0
Po 0 1 0 1
B 60 41 53 61
Si 8 9 8 9
Na 6 5 5 7
Ca 1897 2235 2337 2287
Mg 14 12 10 89
P 659 593 699 691
Zn 773 703 795 824
Vis @210 Flashpoint Fuel antif./water Insol
53-62 >355
54.0 375 <.05 0 0 0.2
BLACKSTONE WRITES:
ADDITIONAL INFO:
Al 2 3 2 3
Cr 1 1 1 1
Fe 16 18 12 10
Cu 43 54 37 21
Pb 1 3 1 3
Sn 2 0 1 1
Mo 91 76 91 70
Ni 0 0 0 0
Mn 0 0 0 1
Ag 0 0 0 0
Ti 0 0 0 0
Po 0 1 0 1
B 60 41 53 61
Si 8 9 8 9
Na 6 5 5 7
Mg 14 12 10 89
P 659 593 699 691
Zn 773 703 795 824
53-62 >355
