Tacoma Extended OCI
by 13Tacoma
06/29/16 01:07 PM
Gear oil mixed in with Diesel Engine Oil ...
by Miller88
06/29/16 12:07 PM
DELO ELC Antifreeze/Coolant??
by Griz95
06/29/16 12:06 PM
Higher oil pressure. Oil? Filter? Jeep 4.0
by RegDunlop
06/29/16 11:16 AM
NJ's gas tax increase
by Whimsey
06/29/16 11:11 AM
PAO in Mobil 1 0w-40
by loneryder
06/29/16 10:33 AM
2010 Porsche Boxster S, Mobil 1 5w50, 4,700 miles
by Croc
06/29/16 10:18 AM
Amsoil announces 6% price hike
by Kuato
06/29/16 09:28 AM
737 NG
by SEMI_287
06/29/16 09:10 AM
ACDelco vs Valvoline oil filter
by mbar1
06/29/16 08:21 AM
Valvoline Premium Blue RestoreTM
by Rat407
06/29/16 08:16 AM
Dealer says 07 Highlander has strainer. Nope!
by CapitalTruck
06/29/16 08:04 AM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
99 registered (Al, alphadog, 13Tacoma, ARCOgraphite, aquariuscsm, 9 invisible), 1995 Guests and 10 Spiders online.
58314 Members
66 Forums
250982 Topics
#761083 - 11/03/06 06:14 AM Flashpoint Testing Method ASTM D-92 vs. ASTM D-93
silverbullet Offline
Loc: Northern California
Does anyone know what the difference is in the test methods between the two?
I recently checked the Dino Pennzoil 5w30 flashpoint as 216 deg. F (ASTM D-93) and Pennzoil Platinum 5w30 flashpoint as 196 deg. F (ASTM D-92).
At first I thought, why would the Dino Pennzoil have a that much of a higher flashpoint than their "best" Platinum line. Then I realized the test methods were different. So it led me to the question of what's the difference in the two methods?
#761084 - 11/03/06 08:01 AM Re: Flashpoint Testing Method ASTM D-92 vs. ASTM D-93 [Re: silverbullet]
Blue99 Offline
Loc: Wisconsin
ASTM D-92 is the Cleveland Open Cup test.
ASTM D-93 is the Pensky-Martens Closed Cup test.
The closed-cup method prevents vapors from escaping and therefore usually results in a flash point that is a few degrees lower than in an open cup.
Base oils typically are 220C+ flashpoints, so it is the volatility of an additive that is producing the lower flash in a fully formulated motor oil.
#761085 - 11/03/06 03:10 PM Re: Flashpoint Testing Method ASTM D-92 vs. ASTM D-93 [Re: Blue99]
Primus Offline
Loc: Kyiv, Ukraine
D-93 value is usually about 20 deg C lower than that of D-92
Edited by Primus (11/03/06 03:11 PM)
#761086 - 11/03/06 08:20 PM Re: Flashpoint Testing Method ASTM D-92 vs. ASTM D-93 [Re: Primus]
bruce381 Offline
Loc: Millbrae, CA
All correct and to add I have always used the PMCC for flash under 200F for light distillates.
bruce
