Medical Errors No. 3 Cause of U.S. Deathss
by doitmyself
05/05/16 02:29 PM
Top Ten Historic Hotel Lacks Designated MC Parking
by LoneRanger
05/05/16 02:19 PM
Toro 120-4276 Oil Filter Cross Ref?
by AirgunSavant
05/05/16 01:42 PM
Using Smoker Indoors
by racer12306
05/05/16 01:23 PM
Misfire and Stumble under load '01 Focus
by Ifixyawata
05/05/16 01:17 PM
Nexus 7 to iPad Mini 4 ?
by Y_K
05/05/16 12:44 PM
2010 camry headlights upgrade
by bmwjohn
05/05/16 12:02 PM
Great presentation on ATF
by Turbo_Lemming
05/05/16 11:59 AM
Great Presentation on Oil Filters
by Johnny2Bad
05/05/16 11:30 AM
long hammer drill bit
by joel95ex
05/05/16 11:25 AM
Mobil1HM 10w-30 vs. 10w-40 in reducing leaks
by 2James1
05/05/16 10:56 AM
Is this a decent price for a Honda mower
by chiefsfan1
05/05/16 10:31 AM
02Maxima, xlittoninjax, Jamer, johaiti, Danielbaja
57803 Registered Users
99 registered (901Memphis, AirgunSavant, aquariuscsm, ABomb369, acmesupply, 12 invisible), 0 Guests and 1 Spider online.
57803 Members
66 Forums
248516 Topics
Page 3 of 3 < 1 2 3
#666087 - 03/13/06 04:12 AM Re: GM 5.3L Piston Slap issue
JohnnyG Offline
Loc: Ohio
It's just a noise, why worry about it? It won't hurt a thing! In both cases.
#666088 - 03/13/06 05:41 AM Re: GM 5.3L Piston Slap issue
Huhwhye Offline
Loc: Los Angeles, CA
So Do 4.8L V8's have piston slap too? Or is it just the 5.3's? I never hear about the 4.8
quote:
Originally posted by tj5450:
To answer the Toyo fans above....
I had a '98 Toyota 4Runner V6 and cured my ails by replacing it with a GMC Yukon. The 4runner had a max speed of 78mph on flat land with two people aboard.
78 MPH?
I call B.ESS. Sure you weren't in 2nd gear? I believe you when you say you like your Yukon better, nothing wrong with that. But you expect me to believe the Toyota only went 78?
#666089 - 03/13/06 06:24 AM Re: GM 5.3L Piston Slap issue
SailSkiDrive Offline
Loc: Maryland
I just went through the piston slap dilema w/ my 2002 Chevy Silverado, however I had the 4.8 V8 not the 5.3. Changing the oil type WILL NOT cure this problem. I was originally using Mobil 1 5w30, but tried Redline 10w30, Super Tech 10w30, and finally Havoline 10w40. I also did an AutoRX in there in between the Super Tech and Redline, it didn't make a difference. The only thing that made a semi-permanent difference was GM's "Top End" cleaner and the problem returned in the less than 3000 miles. The loud tapping also temporarily went away for about two days after a three hour drive up to the Poconos to go skiing.
I know two people at work, both w/ 2002 Tahoes (5.3L) that are starting to make the annoying noise.
We traded my Silverado last Saturday for a new F150, I almost cried. Luckily the truck didn't make the noise once it was warmed up, however it was by far the noisest ever on that morning in 70F! While the F150 is a nice truck I've always owned GM vehicles and I feel EXTREMELY let down by the company.
~Sail [Duh!] [Frown] [Frown] [Frown]
#666090 - 03/13/06 06:37 AM Re: GM 5.3L Piston Slap issue
Gurkha Offline
Loc: India
Piston slap means hammering on the cylinder wall and eventually,lack of compression,nothing to be taken lightly.Can't figure this out,old MB diesel 616/617 engines would start breaking in by 20,000 miles and with just proper care,would happily last 400,000+ miles on average,now with so called new tech,why do we have piston slap?
#666091 - 03/13/06 06:37 AM Re: GM 5.3L Piston Slap issue
Mr. Boston Offline
Loc: Kansas
I hear ya from a used to be GM man. With GM's lack of quality control and customer support they're shedding old customers like Paris Hilton sheds clothing... [Big Grin]
#666092 - 03/13/06 07:57 AM Re: GM 5.3L Piston Slap issue
nevada smith Offline
Loc: Nevada
I just sold my 99 GMC with piston slap. Loved that truck. The piston slap is caused by the short piston skirts. They are short so that they clear the crank on the down stroke. This causes them to rock side to side when they are at the top of the stroke. The piston then proceeds to get rough on the top edge which then chews up the cylinder. The result is lower compression and a damaged engine. Bad design. Chevy was no help. A new Tundra is now in the garage. nevada smith
#666093 - 03/13/06 08:49 AM Re: GM 5.3L Piston Slap issue
OriginHacker21 Offline
Loc: High Desert, California
Can octane in gasoline have any effect on Piston Slap? I did some internet searching and someone said that this can be quieted by going up a grade.
My thoughts - for a lower compression - lower octane??
#666094 - 03/13/06 09:07 AM Re: GM 5.3L Piston Slap issue
Huhwhye Offline
Seem like this would be an easy fix at the factory. Been a problem for a while. Why don't they just use/design a different piston? Seems simple to me. How hard would that be?
#666095 - 03/13/06 09:57 AM Re: GM 5.3L Piston Slap issue
Loc: Maryland
Good point. Supposedly, GM redesigned the "redesigned" piston and put it into production in early 2002. My 2002 Silverado was built in December of 2001.
On another note my BMW Z3 seems to LOVE the Castrol 0w-30 I put in it last weekend. The valve train is definitely quieter than when I had Mobil 1 in it.
~Sail
#666096 - 03/14/06 01:58 AM Re: GM 5.3L Piston Slap issue
Rhymingmechanic Offline
Loc: VA
My April-made 2001 makes what sounds like a valvetrain rattle on hot starts, but doesn't seem to have the cold-start knock.
About 3000 miles into the last OCI, a louder knock developed on cold startup. I added 6 ounces of LC20 (first use in this engine) and the sound went away within 1000 miles.
While my Chevy so far doesn't seem to be built "Like a Knock," I have been chasing an ignition ping since about 15,000 miles. IF the piston slap is caused by carbon, maybe it's been kept away with all the FP60, Techron, Redline SI-1, and Regane I have used to try keeping the chambers clean.
It's hard to know what the truth is with this problem. First GM changed pistons for some people who really complained (or maybe that was second), then they attributed the knock to carbon and did top-end treatments, then they redesigned the pistons. Then, miraculously, they discovered that the noise is normal, nothing to worry about, won't hurt anything, etc. At least they must be saving money on customer relations/warranty denial training, because service writers read me the same script every time I mentioned an abnormal amount of pinging.
#666097 - 03/14/06 06:19 AM Re: GM 5.3L Piston Slap issue
Al Offline
Loc: Elizabethtown, Pa
quote:
Originally posted by Rhymingmechanic:
Then, miraculously, they discovered that the noise is normal, nothing to worry about, won't hurt anything, etc. .
Sounds like the 3.1/3.4. I don't know if it been corrected in 15 years. I believe though that both engines were discontinued last year.
Page 3 of 3 < 1 2 3
