Delo 400 for transmissions?
by Jabbo
08/30/16 04:04 AM
ATF: Dexcon III?
by Jabbo
08/30/16 03:59 AM
List an oil Additive you'd use / No Comments
by SuperDave456
08/30/16 02:33 AM
Driving style doesn't change mpg?
by Nick1994
08/30/16 12:30 AM
Autozone 20% off + free shipping
by jmaster
08/30/16 12:20 AM
Beginners guide to external ATF filters?
by buck91
08/29/16 11:27 PM
Good ADBV filter?
by asand1
08/29/16 11:18 PM
my brigs hates synthetic
by meborder
08/29/16 10:39 PM
Butcher factory cooler lines?
by buck91
08/29/16 09:47 PM
Grease for marine davit crane
by davebe
08/29/16 09:10 PM
2016 Traverse, which oil would you use?
by chevman4life
08/29/16 09:08 PM
acclimating to heat - tips, please
by pandus13
08/29/16 08:53 PM
davebe, Logos, alphanumeric, koidragon1980, iliveonnitro
58961 Registered Users
18 registered (dec219644, EchoTech1945, Farmer, dlundblad, eljefino, CaspianM), 605 Guests and 8 Spiders online.
58961 Members
66 Forums
253757 Topics
#482185 - 08/01/03 03:40 AM Help quick, out of bar and chain oil for chain saw
greencrew Offline
Loc: milwaukee
I'm out of bar and chain oil for my chain saw, and I rented a cherry picker for the day. What else can I use in a pinch?
#482186 - 08/01/03 03:52 AM Re: Help quick, out of bar and chain oil for chain saw
Whimsey Offline
Loc: The Garden State
Not sure, but do you have any gear oil. My chainsaw bar oil seems thick and sticky like a 75+ weight gear oil. Perhaps that can do in a pinch.
Whimsey
#482187 - 08/01/03 04:44 AM Re: Help quick, out of bar and chain oil for chain saw
penzdude Offline
Loc: va beach
30 wt motor oil. penzdude.
#482188 - 08/01/03 05:05 AM Re: Help quick, out of bar and chain oil for chain saw
eljefino Online   content
Loc: ME
you can use 30wt in a pinch but it doesn't have a tack additive. Inertia will fling it off the chain more, make more of a mess, and lube the chain less.
#482189 - 08/01/03 08:09 PM Re: Help quick, out of bar and chain oil for chain saw
Whimsey Offline
Sorry greencreww penns and elj are right, a straight 30 weight in a pinch. I just found the book for my Stihl chainsaw. But if you have a hardware or autoparts store near you you should be able to get the chain and bar oil. I usually buy mine at the local auto parts store, but I know my harware store also carries it.
Whimsey
#482190 - 08/01/03 10:01 PM Re: Help quick, out of bar and chain oil for chain saw
UncleS2 Offline
Loc: Far North East Texas
For some extra tack in that 30w, maybe add & stir in a little STP? Some bar oil would be best, though.
#482191 - 08/01/03 11:16 PM Re: Help quick, out of bar and chain oil for chain saw
MolaKule Offline
Loc: Iowegia - USA
If you like mixing stuff, here is a brew that I currently use:
To a gallon container;
2 pints of Schaeffer's #132
1/2 pint Mobil 1 SS 5W30 or Schaeffer's #701, 5W30 Supreme.
Fill up the rest of the container with Conoco SAE 30 ND or equivalent.
This gives you a semi-synthetic or "blend" bar and chain oil that works in any temperature.
Bar wear has been non-existent on my two Puolan chain saws.
#482192 - 08/02/03 02:12 AM Re: Help quick, out of bar and chain oil for chain saw
penzdude Offline
Loc: va beach
hey kule, if you like mix things, that's alright, but i saw recently in an amsoil mini catalog that they market a bar and chain oil. havn't tried it. i'm guessing it's synthetic. penz
#482193 - 08/02/03 08:17 AM Re: Help quick, out of bar and chain oil for chain saw
bretfraz Offline
Loc: CarMax
Shopping at my local supermarket today they were selling bar & chain oil by the gallon - $2.99. Its in the automotive section. Worth a check of your local store to see what they have.
#482194 - 08/03/03 09:25 AM Re: Help quick, out of bar and chain oil for chain saw
blano Offline
Loc: Canada
Mola, Thats high dollar bar oil. I never heard of someone that pampered a poulan like that.
#482195 - 08/02/03 11:03 PM Re: Help quick, out of bar and chain oil for chain saw
MolaKule Offline
Loc: Iowegia - USA
You can find bar and chain oils at bargains.
Yes, I tend to pamper and keep chain saws for quite a while. Have had these two for ten years and cut wood every spring and fall.
Amsoil does make a good semi-synthetic bar and chain oil.
Most bar and chain oils are Group I SAE 30 with tackifier and little if any AW/EP adds. I wanted my moly and antimony for FM and AW protection. Gotta keep those baby's purring. [Roll Eyes]
I also use use Schaeffer's #706 for the fuel/oil mix and have been very satified with the performance.
#482196 - 08/03/03 07:39 AM Re: Help quick, out of bar and chain oil for chain saw
Rat407 Offline
Loc: North Carolina
I have used Wal-Marts, Tech 2000 bar chain lube for a few years now and is super cheap and has served me well. But then I only cut 3 cords a year at the most, well use to till we moved now no need for the wood. [Big Grin]
#482197 - 08/03/03 05:35 PM Re: Help quick, out of bar and chain oil for chain saw
blano Offline
Loc: Canada
Mola, Many of the cheaper brand bar oils are actually reject hyrdraulic fluids witha additive call visatac added. I have found Stihl(usa) bar oil to be very good, shell canada bar oil is also very good and tech 2000 from wally world in Canda to be very good as well. The tech 200 available in the states stinks. Its way too runny causing it to fling off and leaves the bottom of the bar quit dry. this is rerally evident when using bars over 24".
I actually thought about making my own brew albeit a slightly cheaper one. I wa sgoing to adda quart of cheap 90w gear oil to a gallon of wally bar oil. Incedently walmarts tech products in Canada are made by petro canada and are very good imo.
#482198 - 08/08/03 10:49 PM Re: Help quick, out of bar and chain oil for chain saw
MolaKule Offline
Loc: Iowegia - USA
quote:
Many of the cheaper brand bar oils are actually reject hyrdraulic fluids with a additive call visatac added.
Depends on the formulator/supplier. visatac is just another name for a tackifier, a polyethlylene copolymer.
A cheap 90 weight gear oil thinned down with a synthetic oil can be used in all temps. In fact, I did this in a pinch one time in MO when I forgot to bring enough "brew" to finish out some cutting. I had some straight 90 weight gear oil for the tractor and some Amsoil 5W30 ASL I used at the time for the S-10 pickup. The gear oil had tackifier in it and the on-site brew worked well at 0 F.
