Got into an accident.
by bdcardinal
05/25/16 09:42 PM
Its coming here more and more
by CourierDriver
05/25/16 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
05/25/16 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
05/25/16 08:21 PM
Toolbox - Pliers
by greasegunn
05/25/16 08:09 PM
ProSelect Oil Filter????
by qwerty1234
05/25/16 08:05 PM
Completing your 80% lower with a CNC Machine
by Merkava_4
05/25/16 07:33 PM
Motor oil Sale
by GuinnessGuy
05/25/16 07:26 PM
If Homer Simpson had a Soldering Station...
by Merkava_4
05/25/16 07:17 PM
Peerless/Tecumseh 205-024c
by ford46guy
05/25/16 07:02 PM
Clever Tire Mounting Machine from Corghi
by SubLGT
05/25/16 06:15 PM
Help - transmission filter does not fit the slot!
by 69GTX
05/25/16 06:06 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
102 registered (2015_PSD, 4WD, 69GTX, 1977c10phxdriver, 74DartSport, 04SE, 8 invisible), 1574 Guests and 332 Spiders online.
57973 Members
66 Forums
249408 Topics
#318272 - 07/13/03 06:02 PM How long does an oil filter last?
mrdctaylor Offline
Loc: McGregor TX
Here's the reason for my question. I've been using AMSOIL oil/filters with ~ 1 year drain intervals and a filter change at 6 months. That was when I was putting 12-14K a year on my vehicle.
Now I'm going to only be putting 7-9K a year on my vehicle and was thinking about switching to Mobil 1 oil and a good filter like Wix/Napa Gold and changing both at 7500 miles (prolly 9-10 months). I'm going this route mainly to save time under my truck. I'd rather change everything every 9 or 10 months than to be under there every 6 months changing either the oil and filter or the filter only.
So, my question is this: Will a good filter like a Napa Gold hold up for 7500 miles/10 months or so? Is that pretty safe? I feel like the Mobil 1 oil should hold up fine.
Thanks!
David
#318273 - 07/13/03 06:12 PM Re: How long does an oil filter last?
Patman Offline
Loc: Oakville, Ontario
The NAPA Gold filter should last that long without a problem. In the long life study on the LS1 Camaro, he went to 12k before changing his NAPA Gold filter and the UOAs showed the insolubles level still under the danger zone. Every situation is slightly different though, so I'd do a used oil analysis just to be sure.
#318274 - 07/13/03 07:11 PM Re: How long does an oil filter last?
UncleS2 Offline
Loc: Far North East Texas
David, it would surely be best to do an analysis on the car to see how it was doing. In fact, in a change or two, you'll probably save enough $$ to pay for that analysis! But if it was mine, so long as it was well warmed up at least once a week, I'd run the Mobil 1 & Wix & not worry about it.
#318275 - 07/14/03 05:27 PM Re: How long does an oil filter last?
Spector Offline
Loc: Chattanooga, TN
You missed one option, stay with what you are doing and leave the filter on the full year. I do this on two cars and if you have a well operating clean engine the filter can go the full year or full OCI, no problem. I have done this with Mobil 1 filters and Amsoil. Most filters do very little in the way of protection in a well operating engine. Yes, I have done oil analysis and have also cut the fitlers open after a year, they are fine.
#318276 - 07/14/03 06:19 PM Re: How long does an oil filter last?
mrdctaylor Offline
Loc: McGregor TX
Do the synthetic media filters (AMSOIL, Mobil1, other???) hold up better than the ones made from cardboard or whatever. I assume the NAPA Gold/Wix fall into the latter category. Regardless of mileage, is there a certain amount of the that filter media will start to deteriorate when submerged in oil?
#318277 - 07/14/03 06:27 PM Re: How long does an oil filter last?
Patman Offline
I believe that if the filter is submerged in oil for a long time, it starts degrading a bit and becoming a restriction to oil flow, even if there aren't a lot of miles on it. I don't think this happens all that quickly though, so one year should be relatively safe. It would be interesting to see Bob do a flow test on a filter that was filled with oil and allowed to sit for a year. Test it when new, then test it at one year and see what the difference in flow is.
#318278 - 07/15/03 07:30 AM Re: How long does an oil filter last?
JohnBrowning Offline
Loc: USA
My $.02! Buy cheap ST filters at Walmart and your M1 in the 5Qt Jugs. Change your filter every 5000 or 6 months and be done with it. Filters are so cheap it seems silly to economise on them! $1.67-$1.97 per filter at Walmarts seems a bit cheap to worry about not changeing it out. THe extra oil top off will do your engine good by replenishinging additives and diluteing contaimanents.
#318279 - 07/22/03 06:16 PM Re: How long does an oil filter last?
mrdctaylor Offline
Loc: McGregor TX
Cost isn't an issue--time under the truck is. I am mainly trying to save time while not sacrificing my truck's health.
#318280 - 07/24/03 02:10 AM Re: How long does an oil filter last?
HOndaGuy Offline
Loc: Michigan
get the motorcraft filters if you have a ford. 2.77 at walmart, its in a identical pureone in a purlator casing. another good quality filter is the bosch premium, regardless of what ppl say about the bypass valve, it has done its job of filtering and flow.
[ July 24, 2003, 05:12 PM: Message edited by: HOndaGuy ]
#318281 - 07/24/03 06:18 AM Re: How long does an oil filter last?
Chris Offline
Loc: South
I saw a purlator fall apart in my hand when I tried to look between the pleats. This filter had been on the car for 1 1/2 years. Paper chunks in your motor anyone? [Wink]
#318282 - 07/24/03 10:37 PM Re: How long does an oil filter last?
msparks Offline
Loc: Clarksville, Tennessee
In your situation if your only putting 9-10K on the engine. I feel that the oil and the filter would last that long no problem. Just stick with what you are doing but skip the filter change at the 6 months.
If you using a lessor oil or filter, I would reduce that to the 7500 or 6 months for both the oil and the filter.
Both Amsoil lubes and the Amsoil SDF will last 1 year or 10K. unless you are driving on very dirty conditions or very short trips(ie a farm truck that is only driven in the field, or your car that you only drive 1 mile every day.)
#318283 - 07/24/03 11:07 PM Re: How long does an oil filter last?
msparks Offline
quote:
Cheap filter are cheap! I'd use the top in efficiency and capcity before I would use a $2 filter even if I changed it ever 1000 miles
