Anyone heard of this product? Redline recommended it to me in a response to an e-mail I sent about info on their SI-1 fuel cleaner. They claim that BMW specifically studied it in connection with intake valvue deposits.
At the risk of making the message too long here is the e-mail and Redline's response:
The SI-1 has not been submitted specifically to BMW for approval,
though it would be suitable for use. The SI-2 is a less concentrated
version available in 4 ounce bottles and is recognized by BMW as
being equivalent to BMW Part # 88 88 6 900 307.
BMW EVALUATION OF RED LINE SI-2 from the tech report.
Because of the significant driveability problems BMW
encountered with intake valve deposits, they investigated
fuel properties and many different additives to
help control these deposits. They found very little correlation
between deposits and fuel properties. The
only way to insure freedom from intake valve deposits
was to use additives designed to control these deposits.
Red Line SI-2 was evaluated in this program and
was shown to not only have excellent intake valve de-posit
control properties, but controlled engine tests
showed SI-2 to be free from harmful side-effects. The
parameters measured were engine sludge, ring
groove coking, piston ring, cam and bearing wear, as
well as oil thickening (BMW Report # EA-4 358/88).
The SI-2 when compared against untreated gasoline in
BMW's 730i 100 hour engine test. Deposit formation
was reduced by 94% compared to the base fuel.
The best application of the SI-1 would be a full bottle initially to
20 of fuel, then a maintenance dose of about 1.5 ounces to every 10
gallons of fuel there after. This is more effective than using a full
bottle every 5000 miles as deposits can build up on injectors in
between treatments, the cleaning of intake valves and combustion
chambers take a number of applications to completely remove, a strong
does doesn't fully clean them.
I am not aware of an specific published test data relating to any
effects on engine oil. We state that the combustion by-products do
not cause corrosion of engine bearings as can many fuel additives.
Regards, Dave
Red Line Oil
Still can't find info on the part number or the study.
Regards, Dave
Red Line Oil
